Ribcase split washers
ChrisS
I need a set of split washers for 2nd gear. Does anyone have a source or happen to have a set they are willing to sell? Diagram item # 36, Moss part # 461-835
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
TulsaFred Starting Ribcase rebuild Spridgets 15
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
Rut Ribcase Spridgets 3
N Ribcase Ratio's Spridgets 8
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
L Ribcase transmission with 948 engine Spridgets 8
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Ribcase tranny - painted or bare? Spridgets 7
drooartz Checking a ribcase transmission Spridgets 2
58Custom Who sells best ribcase rebuild kit? Spridgets 6
drooartz Shipping a ribcase transmission Spridgets 17
64rocksprite Ribcase - all the same? Spridgets 4
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
T Ribcase Input/First Motion Shaft source Spridgets 2
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
A Ribcase transmission Spridgets 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Brake Failure--The Line Split Triumph 19
jfarris TR2/3/3A Split Braking System Triumph 8
J TR2/3/3A Split steering column rubber bushing installation. Triumph 4
S TR2/3/3A 37XXX and 27XXX the steering column was split Triumph 6
Boink Split Mini British Motor Corp 0
Boink MGB Split MGB-GT MG 10
G TR2/3/3A Split Steering Rubber Bushing Install Problem Triumph 3
CJD TR2/3/3A TR3 Split Column Triumph 6
J Split steering wheel solution? Triumph 3
G Split loom tubing source Triumph 7
M Split Front Bumper Triumph 1
PAUL161 70 Split Rear Bumpers ??? MG 6
AUSMHLY split-front-bumper Austin Healey 9
I oil snding unit area on engine split Triumph 10
A Rear engine plate split in two! Spridgets 9
W Repairing split in metal water pipe? Triumph 3
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
KVH General Tech Thrust Washers Triumph 2
