Ribcase tranny - painted or bare?
drooartz
The ribcase tranny I'm using looks like it was never painted, just left in bare aluminum from the factory. Is this how they came?
I don't mind painting it (I'd just paint it was a cast aluminum color), but if I can leave it bare that's even easier.
Billm
Bare is how they came from the factory for all of the Spridgets that I have had.
Bill
drooartz
drooartz
That makes things a bunch easier! The transmission cleaned up nicely, so I'll just plan to leave it bare.
Yeah, if they clean up nicely, I leave them bare, if they don't look good bare, I use Duplicolor hi heat engine cast coat aluminum, it about as close as you can get to fresh cast aluminum
kcbugeye1275
I've been told that you don't want to paint a tranny. It needs to breath, might just be an old wife's tale.
tony barnhill
Great Pumpkin - R.I.P
MG's were bare from the factory - don't know about AH's though.
jlaird
Smooth case trannys were painted same as engine, rib case were bare.
tony barnhill
AH's maybe buy MG always left their transmissions bare.
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
TulsaFred Starting Ribcase rebuild Spridgets 15
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
Rut Ribcase Spridgets 3
N Ribcase Ratio's Spridgets 8
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
L Ribcase transmission with 948 engine Spridgets 8
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Checking a ribcase transmission Spridgets 2
58Custom Who sells best ribcase rebuild kit? Spridgets 6
drooartz Shipping a ribcase transmission Spridgets 17
64rocksprite Ribcase - all the same? Spridgets 4
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
T Ribcase Input/First Motion Shaft source Spridgets 2
ChrisS Ribcase split washers Spridgets 1
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
A Ribcase transmission Spridgets 0
M Tranny Mount Bolts Spridgets 3
M Tranny Mount Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R Tranny ? Spridgets 3
2 TR2/3/3A Oil leak in tranny Triumph 4
J TR5/TR250 tranny woes Triumph 15
Got_All_4 TR4/4A Interesting Tranny problem Triumph 9
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
F Ribbed case tranny in 948 bugeye Spridgets 2
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
histerical Datsun tranny help please Spridgets 18
histerical Tranny build Spridgets 0
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
