Ribcase transmission with 948 engine
lbcfan
In fitting a ribcase transmission to a 948 engine- do I need to use a 1275 throwout bearing or use a 948 bearing? I'm assuming that the smoothcase tranny slave cylinder works on the ribcase.
I'm also wondering about the drive ratio for the speedometer. Is it the same with both transmissions?
Thanks in advance.
Gerard
You should use the clutch kit that matches the engine. However, you also need to use the cast steel engine back plate. You should not use the stamped steel plate with the curled edge that is standard to the 948.
The slave cylinder is the same as is the drive gear. The differences in clocking MPH are in the speedo itself. you don't say which car you have, but there may be some speedo differences, but it shouldn't matter if it's original to the car.
L
lbcfan
Gerard-
Many thanks. I hadn't been aware of the engine backplate issue.
The car is a 1960 bugeye that I've had since 1969. Every 20 years I do a little work on the car, whether it needs it or not. This time I've gotten a little carried away...
Gerard
lbcfan said:
Gerard-
...This time I've gotten a little carried away...
I'm sure you are the only one that has happened to... :thumbsup:
TulsaFred
Hey let me know how the 948 does with the 5 spd in a Bugeye.
I'm rebuilding a 1275 and plan to put a 5 spd behind it. However, if I booger up the rebuild it may be back to my 948, which runs great. I've wondered how the car would do with the 948 vs. the 1275.
Fred
L
lbcfan
Fred-
I'm only replacing the smoothcase tranny with a ribcase. Both 4 speed, but the ribcase is supposed to be more robust- bearings instead of bushings, and different synchros I believe. Hadn't considered a 5 speed conversion- I would miss waking the neighborhood with first gear...
Michael
Gerard
TexasSprite
When I got my 59 Bugeye, it came with a smoothcase gearbox which was trashed. I ended up getting a refurbished ribcase gearbox from the late Eric Jones to replace the smoothcase. At the time, I read several opinions on whether or the combination would work or not. Some said that you had to have a backing plate off of a 1275 for the ribcase to work, others said it just bolted on to the 948 backing plate. I was not looking forward to having to pull the engine multiple times to get this figured out. It was clear to me in looking at both transmissions that the geometry of the pivot point for the clutch release lever was different, so I was concerned about having enough extension in the clutch hydraulics to fully disengage the clutch. Eric's trick was to adapt the front cover of the smoothcase to fit the ribcase. That way, you had the same geometry as the original smoothcase. I think all he had to do was to drill two new holes in the smoothcase cover. Anyway, it all fit together perfectly using the 948 backing plate. I even had to shorten the slave push rod a bit to get the feel of the clutch to be perfect. Please realize that I don't have the expertise of many of the posters here on the forum, but so far the setup works perfectly for me!
L
lbcfan
Texas-
Thanks for the info. Before I bought the ribcase I was talking with a shop that rebuilt the smoothcase units with the ribcase guts. Maybe the situation is similar.
I've decided on a clever, fail-safe solution. I'll buy a rebuilt 1275 to attach to the cheap, original ribcase. My wife just loves the idea...
Michael
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
drooartz Checking a ribcase transmission Spridgets 2
drooartz Shipping a ribcase transmission Spridgets 17
A Ribcase transmission Spridgets 0
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred Starting Ribcase rebuild Spridgets 15
Rut Ribcase Spridgets 3
N Ribcase Ratio's Spridgets 8
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Ribcase tranny - painted or bare? Spridgets 7
58Custom Who sells best ribcase rebuild kit? Spridgets 6
64rocksprite Ribcase - all the same? Spridgets 4
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
T Ribcase Input/First Motion Shaft source Spridgets 2
ChrisS Ribcase split washers Spridgets 1
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
