Ribcase - all the same?
64rocksprite
Hello all -
Can I use my 1098 (CG)ribcase tranny on my 1275? I know the clutch assembly is different..is that all?
I see different references (folks selling trans) that say "fits all" Then, I see some referring to a "1275" trans.
If they do fit universally..are the later ones better than the older ones..or truely all the same? (at least when new! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif )
I wanted to do the 5-spd..but don't think the budget is going to allow $1200+ at this point.
Sorry to be a post-hog..I thought I had a plan to finish before June to make the Ozarks..but multiple oil leaks, doubts on a 40+ yr old clutch and so on have me now evaluating the install of the 1275..which I was saving to put in with the 5spd.
Good news is I have a new clutch assy that came with the rebuilt engine!
Thanks in advance! Devin
Bugeye58
Devin, use it. The gear tooth profiles were changed after April, '64, so the gears are not interchangeable between early and late boxes, but the trannies interchange as a complete unit.
The later boxes are stronger than the early ones.
Jeff
64rocksprite
64rocksprite
Thanks for the clarification Jeff!
I'd like to take a peek inside it while its out. What would are the 'usual suspects' to check? - it has 74Kmi on it. Shifts great right now, just doing the 'extra' check while its out and before attempting the drive to the Ozarks this summer.
Or should I change the leaking seals and leave it the heck alone since it is running fine??
Jim_Gruber
Just take some extra oil and drive it. The cost of a few extra qt's of oil pales in comparison of the adventure of the open road and a Spridget on it's way to Arkansas. If you pull the tranny to fix what are the odds of getting it done in time. If it is working leave weel enough alone.
tony barnhill
Great Pumpkin - R.I.P
Were it me, I'd go through it while its out if it has known problems...but, then look at what happened with my '63 I'm getting ready for missouri...hehehe
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
TulsaFred Starting Ribcase rebuild Spridgets 15
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
Rut Ribcase Spridgets 3
N Ribcase Ratio's Spridgets 8
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
L Ribcase transmission with 948 engine Spridgets 8
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Ribcase tranny - painted or bare? Spridgets 7
drooartz Checking a ribcase transmission Spridgets 2
58Custom Who sells best ribcase rebuild kit? Spridgets 6
drooartz Shipping a ribcase transmission Spridgets 17
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
T Ribcase Input/First Motion Shaft source Spridgets 2
ChrisS Ribcase split washers Spridgets 1
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
A Ribcase transmission Spridgets 0
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
tr6nitjulius General TR Different Times Same Glory! Triumph 3
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
drooartz MGB Same car, same spot, 6 years apart MG 12
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
B TR2/3/3A Another/maybe the same fuel delivery problem Triumph 5
jmayzer different part, same situation Spridgets 11
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
K TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover? Triumph 2
drambuie It's funny no matter where Healey owners are in the world, Our garages look the same! Austin Healey 34
weewillie not british but a classic all the same Spotted 6
K TR6 Are TR6 dasboards the same as TR4A? Triumph 5
T Hmmm - not quite the same. What to do? Triumph 10
T TR6 TR3 - TR6 floor pans the same? Triumph 2
Jer No...these cars are not the "same" Spridgets 2
H BJ7 horn button, same as Sprite? Austin Healey 5
