different part, same situation
jmayzer
Member
need to replace the vacuum line on my 1098 midget. yet again, another part that isn't available from moss or vb. do i have to make one? buy used?
jmayzer
jmayzer
Member
SaxMan
Any machine shop with pipe bender tools should be able to make you one. If you can't find one, I know a guy who can probably help you out.
Whitephrog
I just when with the MGA line on a 948cc Bugeye engine. That one has two threaded ends. There are others available that has threads only on one end.
jmayzer
jmayzer
Member
thanks guys!! dave, good to hear from you my friend. i might just take you up on that offer if i can't figure something else out. i'm continuing my research to possibly see if i could fit a cheaper, aftermarket type of line because, after all, i'm a broke college student and this car ain't hittin the concours anytime soon so authenticity isn't exactly high on my list right now...just "drivability.":cool:
SaxMan
On my '69, I used a rubber vacuum line without the fancy fittings on either end and cut it down to fit. Amazing how much nicer the motor ran with a vacuum line that wasn't leaking.
jmayzer
jmayzer
Member
what exactly did you buy for it, david? mind posting a photo so i can see what it looks like?
Pythias
It looks just like 1/4" tubing, but its black. At least that's the way it is on my car. :peaceful: . IIRC I have a barbed fitting on the vacuum unit for just such an adaptation.
SaxMan
Here's a couple of pics from my abortive attempt to put open air cleaners on the Sprite, but they show the vacuum line. I have rerouted it so it doesn't pass through the middle of the spark plug wires. Nothing fancy, just a black hose.
DSC_0022 by David Cohen, on Flickr
DSC_0008 by David Cohen, on Flickr
Pythias
I routed mine the same way as the hard pipe that's being looked for. .... I asked someone at the time who knew if length mattered. NOPE.
C TR2/3/3A Three completely different questions from a TR3B newbie - thanks for any input! Triumph 6
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
tr6nitjulius General TR Different Times Same Glory! Triumph 3
JPSmit and now for something completely different Spridgets 8
K TR2/3/3A Gas tanks...two different types? Triumph 5
AngliaGT Something Different Spotted 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
J Exhaust pressure extremely different between pipes? Austin Healey 20
R TR2/3/3A different hub collars Triumph 7
M SU H-1 Carbs: Are These Just Different? Spridgets 2
Got_All_4 General Tech Different style synchros which is better Triumph 4
Joe Reed MGB A little different DGV installation... MG 12
bugedd Got her leveled out, now with different wheels Spridgets 11
David Townsend TR2/3/3A And now for something completely different Triumph 2
aeronca65t This is a different Spridget Spridgets 6
M Clutch problem, a little different than usual Spridgets 8
C Wiper arms different lengths? - BJ8 Austin Healey 6
V TR2/3/3A Something Different Triumph 20
Lukens TR2/3/3A Are there different lengths for stator tubes? Triumph 3
T General Tech How different is NPT thread from BSP thread? Triumph 2
aeronca65t "Different" Swap Sunbeam (Rootes) 3
zedvictor1 Spitfire different diff for Spit 1500 with overdrive? Triumph 1
KVH TR4/4A Two 4As--why so different? Triumph 4
J Different Shifters? Spridgets 3
Xte Two different springs in distributor ignition ? Austin Healey 4
CZ_Dave Well, That was different! MG 4
aeronca65t A "different" E-Type Jaguar 4
M exhaust sound different. brith/jap Spridgets 14
Sherlock Something a little, ahem, different... Other Cars 3
rlich8 TR4/4A How is the TR3 different from a TR4A Triumph 7
BugeyeNJ58 Different lengths of wiper motor cables? Spridgets 9
glemon TR6 TR250/early TR6 v. late TR6 Different Speedo Ratio Triumph 4
Trevor Jessie Different type of forward tilt. Spridgets 5
AngliaGT A Few Different Ones... Spotted 0
H Car's personality different based on paint color? Austin Healey 7
S And now for something COMPLETELY different...... Other Cars 7
lbc_newbie Things are different in SC! Spridgets 3
T Spitfire A different Spitfire gas cap question Triumph 3
Trevor Jessie Siblings can be so different. Spridgets 1
BugeyeNJ58 PCV Valve - can I use a different type? GULP VALVE Spridgets 5
T OT - saw the hanger from a different POV today Triumph 13
Sherlock A rather different motorbike... Other Cars 6
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
G A horse of a different color Spridgets 26
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
Hap Waldrop A different approach Spridgets 12
Rob Glasgow Wow, now that feels different... Austin Healey 20
T different vacuum timing thread. Triumph 13
C Different springs for different years??? Spridgets 16
M My problem ended up being a different problem.. Spridgets 7
