TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover?
karls59tr
Bronze
I accidentally knocked a TR6 top cover off the work bench and I must have dislodged one of the detent balls. I have a top cover from a 4A that I could use rather than try to repair the damaged one. Are they the same.....both are synchro in first?
TR3driver
Great Pumpkin - R.I.P
I believe they interchange, as far as the shift fork locations go. There were a lot of variations in TR6 top covers, but mostly in where the switches were located and how the shift detents were retained.
https://trf.zeni.net/TR6bluebook/82.php
glemon
Would agree, don't think the 4A had back-up lights, so there is a switch for that you will be missing, but it should work otherwise, other variations would be overdrive switches which allow the O/D to work in certain gears but not in others, but it is not too hard to add these as needed, as far as how they work with the tranny to shift the gears pretty sure they are interchangeable if not exactly the same.
Good write up on rebuilding the top cover on the VTR website if you decide to stay with what you had.
https://vintagetriumphregister.org/maintain/TransRebuild/TRTrans02.pdf
PeterK TR2/3/3A Saturday Freebie - Gearbox top cover Triumph 3
K TR2/3/3A The round electrical connectors on the OD Gearbox Top Cover? Triumph 1
T TR2/3/3A TR3 Gearbox Top Cover OD Switch Locations Triumph 6
sail gearbox top cover non to od Triumph 10
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
F Sprite Gearbox Spridgets 5
E Gearbox problem Other Cars 0
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
K TR2/3/3A Further to changing motor and gearbox mounts. Triumph 1
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
AHS Side-Shift Gearbox Austin Healey 3
D Gearbox Dipstick (BT7) Austin Healey 3
K TR2/3/3A A gearbox additive? Triumph 3
C Gearbox oil British Motor Corp 3
JFS Wedge Stripped gearbox filler hole thread Triumph 3
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
R 100 Motor and Gearbox Available Austin Healey 2
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
W BN1 Gearbox First Motion Shaft Austin Healey 0
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
KellyRob BMC GEARBOX 1960 British Motor Corp 2
Hamish Racing TR2/3/3A Gearbox - can you spot the problem ? Triumph 17
C TR2/3/3A TR3 Gearbox Problem Triumph 10
D MGA with T9 gearbox on a tow dolly MG 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
S Add ZDDP to gearbox oil? Austin Healey 29
R TR6 Gearbox slips out of 3rd gear Triumph 14
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
Lin Gearbox Oil Austin Healey 4
R TR6 Proper alignment of gearbox front cover plate Triumph 3
BN6_2197 How regular should I change the gearbox oil? Austin Healey 5
R TR6 Gearbox rebuild issues Triumph 8
S Steering Peg in Steering Gearbox Austin Healey 13
K Gearbox Throw-out pin and gasket question Austin Healey 8
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
AH67 59 xk150 gearbox Jaguar 6
G Wanted Non Overdrive gearbox wanted Austin Healey Classifieds 0
Bayless Started adapting the datsun gearbox today Spridgets 46
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Editor_Reid General MG Gearbox Identification MG 2
Editor_Reid Gearbox Identification Austin Healey 12
W XKs Motorsport gearbox rebuild fiasco Jaguar 5
