1275 Ribcase transmission in Bugeye - Which slave and pipe?
TulsaFred
I took out the 948 and smooth case, and am about to install my 1275 and ribcase.
My original set up is a 7/8 dual bore master, a 3/16" od pipe with male fittings one each end, which attaches directly to the BE slave. The pipe is 93" long.
The 1275 ribcase set up is a 1/4" od pipe and correspondingly larger thread, with a rubber hose between the pipe and slave. The pipe was apparently only 40" long, so must have been routed differently.
So what is the best set up to use?
I'm thinking I'll just use the BE slave on the ribcase and keep everything stock from the original. Any problems or deficiencies with this simple solution?
Other options?
(BTW I put in the copper nickel brake pipe set from Moss, and now I'm contacting their supplier, Automec, about a matching copper nickel clutch pipe. They can customize that pipe in any way I want)
Fred
nomad
Fred, I took the end from an old 1275 clutch hose and welded in the correct fitting for my bug eye coiled pipe set up. Another option!
Kurt.
Gerard
Other options?
Fred
Fred,
It's fine to use the 7/8" salve cylinder used with everything prior to the 1275, but you would do well to upgrade to the 3/4" conversion I provide for the master cylinder. I don't recall if you're upgrading to disc, but I definitely recommend that upgrade for both bores if you are. I can also do just the clutch side. With the 1275 diaphragm clutch, you'll find a significant improvement in the feel of the clutch. The same is true of the brake with discs.
TulsaFred
TulsaFred
The upgraded master cylinder will be on my list when I upgrade to discs later.
For now I guess I'll just buy a new 7/8 slave and keep everything else stock from the BE as well.
Seems like there were issues concerning pushrod lengths with the various set ups ?
Gerard
Fred, see my web page for data on pushrods and much more.
https://gerardsgarage.com/Garage/Tech/TO_Bearings/tobearings.htm
For the 948/1098, the push rod should be 2-3/8" from hole center to end. For the 1275, the push rod should be 2-11/16" from hole center to end.
TulsaFred
TulsaFred
I keep forgetting that Gerard's website should be my first place to check on such things...
TulsaFred
TulsaFred
If I have a 1275 and ribcase with the 948/Bugeye's 7/8 slave cylinder and master cylinder, do I:
1. Use the throwout bearing and pushrod from the 1275 (more offset bearing, 2 11/16 rod), or
2. Use the throwout bearing and pushrod from the 948 (less offset bearing, 2 3/8 rod)
Gerard
Fred, check my site again, as all the info is there.
Short version = the release bearing must match the clutch. If you are using 7/8" slave, match the pushrod to the slave.
TulsaFred
TulsaFred
got it , thanks
TulsaFred
TulsaFred
Everything installed and bled (although the brakes don't seem to want to bleed completely...).
Now I can't get the clutch to release. I adjusted the master cylinder pushrods all the way out (maximum length so that the piston begins to move with minimal pedal movement), still won't release the clutch.
I removed and measured my slave pushrod on calipers. It is 2.45-2.5 " from center of hole to end of rod. I think this is the 948 pushrod.
Gerard said to match the pushrod to the slave, which is the 7/8"/948 slave. However, it seems like I'll need to use the longer pushrod for the 1275 (2 11/16" or 2.6875").
Thoughts?
(BTW the measurement of the pushrod I have was made from the very end of the rounded rod to the center of the hole - 2/5". If I measure from the hole center to the point at which the taper begins for the rounded tip it is approximately 2 3/8")
Jim_Gruber
Fred,
A piece of Threaded Rod with a Union in the middle will do to get things going until you get the correct rod. Just don't overextend it and bend the folk. That could get things going today.
TulsaFred
TulsaFred
Thanks Jim.
I found an old rusty long pushrod- was actually over 3" long. I think a previous owner of on of my spare trannys must have fabbed it. Anyway, I cut it down to 2 11/16 long and put it in the car.
Still won't release the clutch!
Looking it over, I am thinking the master cylinder may not be giving a full stroke. It may be that the pistons are not fully returning , perhaps bad seals. Barring any better ideas I'll order some new master cylinder seals and see if that fixes it.
Any easy way to tell if the MC piston is not fully returning while it is still in the car?
nomad
Should be able to feel it by the pedal. You can definitely tell by grabbing hold of the rod that goes into the MC and moving it around.
So, if its not returning then you still haven't gotten the air out of the system?? That was going to be my diagnosis.
Kurt.
TulsaFred
TulsaFred
I think I got all the air out of the clutch system. I didn't think air was a cause for incomplete piston return in the MC. I could be wrong. I think more of deteriorated seals jamming the bores and not allowing piston return.
nomad
No, what i meant is that if the MC is giving trouble you might not have gotten all the air out and that could have something to do with the clutch not wanting to release. I've had those MC's apart several times and they do have to make a full stroke to allow fluid and air to move freely in and out.
Kurt.
TulsaFred
TulsaFred
I had the car on the lift and my daughter operating the clutch pedal. I took the rubber dust boot off the slave and watched as she depressed the clutch. Full travel confirmed. I took of the rubber inspection cover on the side of the bell housing and watched. The pressure plate seemed to fully depress with the actuation of the pedal/slave.
Still no clutch release.
Oddly, yesterday it randomly worked for a short period and I took the car for it's first drive in about 3 years. It was great, the 1275 and ribcase is a big upgrade from the 948 and smooth case I had in it before. Glorious. Motor ran smoothly and strongly and went through the gears on the trans w no problems. Perfect.
Then as I pulled it back into the garage the clutch wouldn't release again. Strange.
So at this point, I am suspicious of a jammed pilot bushing or a defective clutch pressure plate or disc. Not happy to pull the whole engine trans back out to see.
nomad
Bummer, Fred.
Can you risk driving it some more to see if it will come out of it?
Kurt.
Rut
Fred,
Did you soak your pilot bushing in oil fir 24 hrs prior to installation? I know it's a long shot, but...
Rut
TulsaFred
TulsaFred
I hate to admit, but I didn't replace the pilot bushing! I felt it with my finger and it seemed "ok". Maybe it is or maybe it isn't...
One thing I tried was lifting the car, putting it in gear (2nd with the sychro and the wheels able to spin got in in gear without grinding).
I revved it slightly, pushed in the clutch and then hit the brake to try to jar it loose. 3 or 4 attempts were a no go, the engine just stalled.
Any other ideas?
I keep telling myself that the fun is in the process not the end result!
BlueMax
Difficulty adjusting clutch pedal freeplay?
Possible Causes:
Clutch disc installed backwards
Flywheel bolts improper-head of bolt too large
Flywheel worn-improper resurfacing or too thin
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
M Wanted 1960 Bug eye sprite 1275 ! Austin Healey Classifieds 0
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
doc50 Wanted H2 SU carbs / manifold for 1275 1973 MG MIdget Spridgets Classified 3
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
Gerard 1275 piston ID Spridgets 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
Rut How much does a 1275 weigh? Spridgets 8
