TR6 Are TR6 dasboards the same as TR4A?
Gauge openings and layout are pretty much the same. Its the fresh air vents on the ends that are the biggest difference. You could swap out the metal dash frame underneath the wood and make one work either way.
Marv
3798j
Bronze
TR4A speedometer is on the right hand side of the steering column, TR6 speedo is on the left.
sd80mac7204
There are a few differences as to switch size, type, and location. Gauges are the same size but otherwise they can be very different depending on year and equipment.
Foura
The centre switch panel is different also. On the 4A, the "cowl" is under the switches, and the bottom of the timber dash is straight at that point. On the TR5/6 the cowl is over the switches and the bottom of the dash is indented to suit. How do I know all this? The timber dash panel on my 4A is a bitsa. 4A air vents with 5/6 centre panel. Long story. All you need to know is that it looks great and was cheap!
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
T TR6 TR6 Tire Pressures Triumph 2
