1275 to 948 Generator Swap - Need Input Please
mxp01
All:
As was mentioned previously, I recently purchased Ray Evans' Whitephrog. I'm in the process of reassembling the car. It came with a 1275 that I swapped it out for a 948. I've been pretty deliberate with a fine eye on details. I'm working off memory (I previously owned a BE), some photos, and a parts catalog. Today, I ran into a real problem swapping the generator off the 1275 and on to the 948. It is an original generator for the cable driven rev counter. Here is my key issues right now:
1. I have the fan belt off the 1275. It looks a bit small. Moss lists a different p/n for a 948 fan belt. Is the 948 belt a bit larger? (I called Moss, the operator just confirmed it is a different part).
2. The lower bracket (front of engine to third hole on generator; adjustable) from the 1275 just looks to be a hair short for the 948. Did the 948 use a different bracket? Moss lists one p/n for a bracket (called a "link" in their catalogue) for all three engines. Is this a larger, universal bracket?
I'm looking to place an order tonight to get what I need. Any input will be greatly appreciated.
Mike Pennell
markberry
I can measure the overall length of mine (adjusting link) when I get home this afternoon if that might help.
mark
markberry
Hi Mike,
sorry I couldn't get back to you yesterday. The overall length of the adjusting link is about 8" to 8 1/4". I couldn't get the tape measure in there very well. The distance between the points at which the link is bolted to the engine block and the generator is 5 3/4". That measurement would vary of course with the length of the fan belt installed, but I just thought I'd throw it out there in case it helps.
regards
mark
M
mxp01
Mark:
Thanks for taking the time. My current bract is 6" in total. I have a new once coming tomorrow from Moss that I hope will do the trick.
R 948 convert to 1275 info Spridgets 13
A Bugeye engine swap, 948 to 1275 Austin Healey 11
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
longbridgehealey speedo cable 948 to 1275 Spridgets 2
longbridgehealey another 1275 from 948 question Spridgets 3
B MG Motor - 948 parts or 1275 engine MG 1
M Differences in Slave Cylinders for 948/1098 & 1275 Spridgets 5
I Top speeds for 948 and 1275 engines Spridgets 16
M 948 vs 1275 - Looking for opinions and ideas Spridgets 34
T Jetting Weber DCOE for 948 and 1275 cc Spridgets 3
VelodromeRacer CHange backplate on 948 with 1275 unit? Racing 9
Z 948 carb on 1275? Spridgets 12
D Swapping 948 for 1275 engine Spridgets 11
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
