MGB First Motion Shaft
MGB 67/64
My question is how to bend the lock tap washer on the first motion shaft once the left handed nut has been tightened. There is not much material to work with and wanted some ideas from others on this problem that I'm having. Would it be okay to put a drop or two of thread sealant on the threads to solve this problem.
Thanks,
Joe
Platinum
Hi, Joe and welcome to the forum.
The method I've used for the job is to use a pair of Channel Lock pliers, after starting the bend by prying the tab a bit away from the bearing face with a "claw" of some description. And a drop of thread-locker wouldn't do any harm, either.
Platinum
Someone you may want to look up is Jim Boffo in New Brighton. Used to be a BMC/BL dealership:
Boffo Motors
M
MGB 67/64
Hello to All,
Happy to report that the hammer and chisel method was successful. Just had to remind myself to be patience and take my time. I have the tab bent over!!! :cool:
Thanks,
Joe
Platinum
:thumbsup:
LarryK
LBCs are a practice in patience and contirtionism.
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
W BN1 Gearbox First Motion Shaft Austin Healey 0
R Repair a First Motion Shaft for a Austin Healey 3000 Austin Healey 7
R Wanted First Motion Shaft for a Austin Healey 3000 Centershift case Austin Healey Classifieds 0
4tecdog Play in first motion shaft on BJ8 Austin Healey 3
Tullamore BN1 3 Speed Transmission Third Motion Shaft Disassembly Austin Healey 3
T Ribcase Input/First Motion Shaft source Spridgets 2
zimmy first motion shaft bearing clip Spridgets 9
drooartz MGB MGB in motion MG 2
K GT6 Exhaust smell when car in motion? Triumph 5
B E Type rack and pinion motion Jaguar 4
A TR4/4A Lost motion lever - what is it for - TR4 Triumph 2
ez_pa_6 Artistry In Motion Triumph 1
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
WHT Rocker Arm Shaft Replacement Austin Healey 21
D XK150 Transmission Input Shaft Jaguar 1
Rut MGB 62-67 upper MGB steering shaft MG 3
G Installing New Rocker Shaft Assembly Austin Healey 3
D Spedo shaft direction Spridgets 6
Michael Oritt Propeller Shaft Hardware Austin Healey 6
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
T MG Midget 1500 crank shaft pulley Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
R TR6 Drive shaft orientation Triumph 3
S TR2/3/3A Replacing the cam shaft Triumph 27
S Removing Overdrive Shaft Lever Pin Austin Healey 7
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
P Wanted BN1 can shaft Austin Healey Classifieds 0
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
C Bugeye propeller/drive shaft- universal joint Spridgets 1
Walter74 Kent AH4 cam shaft Austin Healey 18
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
L TR2/3/3A Drive shaft question Triumph 5
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
J General TR Cam shaft upgrade????? Triumph 3
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
