I believe the rib case is not bullet proof, but quite good. I know prices vary due to many factors - Supply / Demand / Honesty / Knowledge. Supply and demand are major and can't do much about either. My knowledge may have a direct impact on their honesty. And my knowledge is sorely lacking when it comes to Rib Case transmissions.
1) What is a general average cost for one that is supposed to be in "good condition when removed, shifted well, synchros seemed OK, but I really don't know anything about the history"?
2) General average cost for one that is "recently looked at by someone who knows"?
3) I have good mechanical experience, but not with Rib Case. What can I look for with out full tear down?
Obvious is drain some gear lube (if it isn't dry) and look for metal flecks. Input and output shaft radial play, but I don't know what is normal/OK. I have a dial indicator that may help. Also, look for any obvious spline wear.
Can you really see anything important by pulling side or top cover, and is it somewhat obvious if you are not familiar with what you are looking at?
