TR2/3/3A TR3A...Tighten Diff Case Bolts?
karls59tr
Bronze
Is there a trick to snugging these bolts tight? The lip on the case flange prevents getting a wrench on properly and a socket as well. I've got a leak at the bottom...might be time for a new gasket.
TR3driver
Great Pumpkin - R.I.P
I must be missing something, Karl. Either a socket or a box-end wrench will fit on mine.
Generally, tightening them won't help anyway, it will only distort the flange and make the leak worse. If you're sure that is where the leak is, my advice is to pull the cover, make sure the flange is flat (not dimpled around the screw holes as they usually are), coat a new gasket (you can cut your own from sheet cork) on both sides with Hylomar, double-check that the bolts do not bottom in the holes, and reassemble with new lock washers.
Geo Hahn
Do you have lockwashers under the heads? That may make them stand proud enough to get a wrench on and also tells you how tight is tight.
If you go the gasket route... pretty easy to make your own and possibly necessary -- the one I bought from one of the big 3 vendors was useless, holes didn't match up.
K
karls59tr
Bronze
Ah ha! I'll bet there's no lockwashers under the heads and that's why the poor grip with the wrench. I'll straighten the flange as well like Randall suggested. Thanks guys.
prb51
follow the torque recomendation in the manual otherwise it'll leak more than ever.
Get a new gasket and seal it with a little sil/goop
MGTF1250Dave
Good advice. If you still have a leak after a new gasket is installed, check the seal on the input flange. A leak there results in oil trailing down the under side of the differential and dripping off the drain plug. It looks like a leaky gasket under the cover plate. A lesson I learned by experience.
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
angelfj1 TR2/3/3A TR3A Stone Guards Triumph 3
Hamish Racing TR2/3/3A 1959 TR3a used in anger Triumph 5
