TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4
KVH
Well, I have two straight forward questions:
1) Should I use thread-lock or lock-tight on the Flywheel bolts when I reinstall the flywheel?
2) That steel plug for the rear oil galley hole. The one behind the flywheel and next to the camshaft plug. Mine may be leaking--has anyone pulled that plug? How is it done and where did you get the replacement.
Alan or Geo, this may be something you guys once did???
Thanks, all.
martx-5
These cars were made pretty much before the lock-tite era. That doesn't mean that it wouldn't be helpful. It's good stuff, but just don't overdo it, as sometimes the bolts can be difficult to remove if too much is used. One drop per bolt should be sufficient.
As far as the welch plug goes, now would be the time to replace it if you feel it is leaking. Moss Motors lists the part on this page as item #26. It's probably just a common freeze out/welch plug available at just about any auto parts store. The biggest problem is getting them out. The last time I had to pull out a welch plug was on my daugter's first car, a Pontiac Sunbird. It had to make a hole in the plug, kind of expand that with a chisel and then pry it out with a large screwdriver. Putting the new one is is much easier then extracting the old one. /ubbthreads/images/graemlins/hammer.gif
KVH
KVH
I think #26 is for the camshaft, and the front one listed as #25 looks like it has threads on it. There must be a front and rear for #25. Do you agree?
Geo Hahn
Didn't the flywheel bolts have locking plates (2)? I think they would have originally.
Some folks use self-locking bolts (the kind that stretch) for this application but IMO locking plates make things pretty secure.
KVH
KVH
No locking plate. I don't know the reason, but the manual says that "place bolts" are used on some of the models or engines--after some point in time. I have no idea what a place bolt is. When I took them out, they looked like they had some kind of substance on them, not necessarily lock-tight.
Geo, pulling the transmission is not so much fun. I can't imagine doing it and then having another oil seal problem and doing it again. If I spend much more time beneath my car my wife might just lower it on me before heading out.
Alan_Myers
Yes, tab washers were normally used and are probably the best security for the flywheel bolts. I'd use Locktite, too. (On the ring gear, too, which also has tab lock washers.) Can't be too safe with the flywheel!
The galley cap just gets tapped into place, if I recall correctly. It expands and is trapped in there. However, an old trick that's a good idea is to clean it all up really well around it (degrease it with acetone or lacquer thinner), and use epoxy to secure and seal it. Any siginificant oil leak there will quickly leave an engine without any of its life blood!
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
JFS TR6 Rear Oil Seal? Triumph 1
J TR4/4A Oil leak from rear of motor. Triumph 28
warwick-steve Oil for rear axle? Austin Healey 3
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
J Rear Oil Seal Kit - Spring Austin Healey 9
B How often should you change the rear rear axle oil Austin Healey 9
D Oil Leak at rear of oil pan Spridgets 11
drooartz Rear wheel hub oil seal Spridgets 6
B TR2/3/3A Checking oil in rear axle Triumph 2
AUSMHLY Oil in rear carb Austin Healey 33
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
AUSMHLY BJ8 rear axle oil seal Austin Healey 6
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
B TR6 Rear Oil Seal Housing Triumph 2
B TR6 1971 clutch and rear oil seal Triumph 2
S Rear crank seal oil leak BN2 Austin Healey 20
1 TR6 oil for rear shocks Triumph 5
R transmission and rear end oil Austin Healey 2
B Rear Wheel Bearing Oil Seal Spridgets 7
CanberraBJ8 Rear axle oil seals - which way is out? Austin Healey 18
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
F More oil leaking...rear seal? Triumph 3
D Oil On Rear wheels MG 6
6 Rear Axle Oil Seals Spridgets 4
M Rear Oil Leak Spridgets 5
A Rear Axle Oil Seal Spridgets 2
P Rear axle oil seal Austin Healey 4
T Rear axle oil seal Austin Healey 4
T rear axle oil seal replacemeent Spridgets 15
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
rjc157 moss rear crank oil seal Austin Healey 4
B TR6 TR6 rear axle oil change Triumph 21
J Rear Axle/Differential Gear Oil Spridgets 13
TR3TR6 TR2/3/3A TR3 rear oil seal Triumph 2
vette Crankshaft Rear Oil Seal Austin Healey 11
mgnewbie Speedi-sleeve for the gearbox rear oil seal MG 7
PAUL161 72 Overdrive rear oil seal question. MG 0
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
longbridgehealey oil from rear axle shaft Spridgets 16
B Help to replace 3000 leaking rear axle oil seal ? Austin Healey 25
ncbugeye Oil from rear hub Spridgets 3
Dudly Rear Diff Oil Triumph 11
C Need info on gearbox and rear end oil for midget Spridgets 5
drooartz Removing the $@#! rear hub oil seals Spridgets 3
R correct rear axle oil Austin Healey 1
