Rear hub nut size
boxfullofyertoys
Quick question...
I'm in the process of swapping my rear end housing (due to a few broken bits), and I need to know the size of the nut(s) on the inside of the drums so I can remove the hubs on both sides. Any ideas on how big they are? Is there any trick to taking them off?
Thanks!
Another tip, I bought a socket for this, it was bevel on the end and I couldn't get all the way on the thin hub nut, os I chucked up in the lathe, and turn the bevel/radius off the end of the socket so I could get all the way on the nut, so look at your socket choices, and be ready to customize it for this job. On re=assembly, I don't use the tab washer, thet thing is a joke, I cealn all the tread , free of oil and grime, use red loctite, and torque to 100 ft. pounds, I've seen people use a chisel and hammer to do this, very bad idea.
Jim_Gruber
Think about a local Farm Supply Store for the socket. Got one at Tractor Supply for $7-8. Sears wants 2.5 x's as much for a socket you'll use once or twice.
nomad
You will need a bearing puller and a piece of plate with a centering hole to pull the hubs off the axle tube's as well.
KA.
Jim_Gruber
No Bearing puller, I just turned the rear drums around, put on a couple of lug nuts and made use of the rubber mallet. Axles slid right out with very little effort.
boxfullofyertoys
boxfullofyertoys
Thanks for the pointers. It will def be a big help.
I decided to shoot over to Harbor Freight on my lunch break to see if they had anything large enough, and all they had was a few large adjustable wrenches. Sears Hardware (thankfully right across the street) didn't have much either (out of stock).
I did however encounter a conundrum: The socket I need is a 3/4" drive. That means I'd have to get the socket and the socket wrench, which is a costly proposition given I'm going to use it all of 4 times.
What do you think is the best way to go without having to modify anything or spending a ton? Will a beefy adjustable wrench suffice? I obviously don't want to half-ass the job, but at the same time I can't justify spending a ton of money for something that's barley going to get used....
JPSmit
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2117
you can buy all kinds of adapters.
I bought the 3/4 set - it is amazing how often I use it - not just for the nuts that size on Ms Triss (rear hub, crankshaft, oil cleaner bracket) but as a drift and various other things. plus I get to impress the heck out of my friends with a 3/4 drive - (Insert Tim Taylor arr arr arr sounds here)
cost about $50
boxfullofyertoys
boxfullofyertoys
Hmmmm...it looks like I'm going to have to take another swing over to HF...maybe I missed something!
Brian_James
You might want to get a 3/4" drive breaker bar for this one job. If you have a Northern Tool nearby you might want to check them out. They seemed to have a pretty good selection of individual sockets, and wrenches. Stuck me as an upscale Harbor Freight. You can always check the prices online.
Brian
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
D Left rear hub nut Austin Healey 9
B Right hand side rear hub nut Austin Healey 3
letemglow Torque setting of rear hub nut Austin Healey 24
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
B Rear Hub Nut Spridgets 13
D rear hub nut size? MG 11
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
W Rear Hub Reassembly Austin Healey 7
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Rob Glasgow Rear Hub Nuts Austin Healey 11
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
J TR2/3/3A Hole in Rear Hub Triumph 7
K Rear Hub Re-assembly Austin Healey 4
KVH General TR Rear Hub Backing Plate Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
K TR2/3/3A Rear axle hub removal? Triumph 8
G Loose lugs on rear hub Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
T TR2/3/3A Rear Hub Stud Removal Triumph 4
AngliaGT TR6 Need a Rear Hub Triumph 1
C Rear Hub Removal - How Do I? Austin Healey 8
D Rear hub confusion Austin Healey 5
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
B Spitfire advice on rear axle/hub Triumph 4
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
B Rear Hub Extension Studs Austin Healey 22
J Rear Hub/Bearing Question Spridgets 4
PHerder Rear Hub Removal??? Spridgets 10
Dougal BN1 rear hub markings Austin Healey 3
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
Barryp Rear hub seal speedy sleeves? Austin Healey 2
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
T REAR HUB REMOVAL Spridgets 4
JPSmit Rear Hub Question Spridgets 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
MadRiver Rear Hub Puller? Austin Healey 4
glemon Bent Rear Hub/Axle Triumph 2
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
D Rear Hub install Austin Healey 2
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
