Rear hub confusion
DickN
Member
I did an search find out about rear hub oil leaks. I found that:
1. the hub bearing is lubricated by the differential oil.
2. The paper gasket and O ring should stop the oil from leaking.
3. the oil seal (inside the hub) is to be placed with the open end towards the bearing.
What is the purpose of the oil seal if oil normally gets past it to lube the bearing?
Before I spend $40- $50 on a socket to remove the nut, Can I stop the leak by just replacing the gasket & O ring?
Thanks
Dick
GregoryW
The seal keeps the oil from leaking out through the back side, and the gasket/O ring take care of the outside. You'll see how the seal works after you pull the hub.
What's confusing you, and what you can't tell from looking at the pictures, is that the axle shaft passes through the bearing, but it's much smaller than the inner race, and the 2 don't touch. Oil is free to pass from the axle housing to the inside of the hub.
I was very impressed with the design after we blew one of the seals this summer. There was axle grease everywhere, but the brake shoes were high and dry.
The hub and brake backer plate are designed so that the leaking grease is slung off under the car through the backer plate, and away from the brake shoes.
The gasket is a bit of a mystery to me. It sure seems like the O ring would do the job all by itself. Does anybody know?
To answer your question, the leak is probably coming from the seal, as it is a wear item. The O ring doesn't see much action. Check the back side of the backer plate. If it's oily, it's the seal.
I didn't need a wrench to get the nut off. It was fairly loose (too loose), and held in place with a bent-over washer. Be aware that the nut on the left side has left-hand threads.
You'll probably need a press to remove/replace the bearing. The seal is a pain to remove because, as you noted, it's in there backwards, so you can't just hook it with a seal puller (screwdriver).
Greg
57_BN4
The grey painted hub nut remover socket commonly sold isn't hardened and mushes up upon the first use. If you have a club nearby see if you can get a loan of a communal one which has a pilot shaft that fits inside the axle hole and prevents the socket slipping off the nut. You'll need a two or three jaw puller too to remove the hub from the axle.
A bench vise and two big sockets is sufficient to remove and replace the bearing. Warm the hub with a propane torch to start it moving if it won't budge with moderate pressure. Too much pressure and the bearing will be damaged.
The oring and gasket setup is somewhat illogical in that the oring seals against the gasket. I think the oring was a later addition as the early BN1 hypoid axles don't have an oring, just a gasket. Presumably when the splined hub is removed it releases the clamping load on the gasket enough to leak oil onto the brakes and the oring was added as a backstop. Replace the oring and put silicone sealer on the gasket too as it only takes a few drips out of the flange to ruin the shoes.
Andy.
steveg
I've used pvc pipe fittings of various sizes as seal drivers. Was able to R&R the bearing using this method.
Slight quibble: the seal is not actually in backwards, though it looks it, as the spring side points toward the bearing, where the oil is.
British_Recovery
Bronze
As far as the thin paper gasket on the axle flange, there are two different ones. The earlier hub, without the o-ring, uses a paper seal with a smaller inside circular opening, while the later seal is cut back so the o-ring is between metal surfaces and not against the paper. They look exactly the same until you line them up.
Bob
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Axle Hub Seal Austin Healey 8
W Rear Hub Reassembly Austin Healey 7
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Rob Glasgow Rear Hub Nuts Austin Healey 11
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
J TR2/3/3A Hole in Rear Hub Triumph 7
K Rear Hub Re-assembly Austin Healey 4
KVH General TR Rear Hub Backing Plate Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
K TR2/3/3A Rear axle hub removal? Triumph 8
G Loose lugs on rear hub Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
T TR2/3/3A Rear Hub Stud Removal Triumph 4
AngliaGT TR6 Need a Rear Hub Triumph 1
C Rear Hub Removal - How Do I? Austin Healey 8
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
B Spitfire advice on rear axle/hub Triumph 4
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
TulsaFred Rear hub oil seals and bearings Spridgets 7
B Rear Hub Extension Studs Austin Healey 22
J Rear Hub/Bearing Question Spridgets 4
PHerder Rear Hub Removal??? Spridgets 10
Dougal BN1 rear hub markings Austin Healey 3
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
Barryp Rear hub seal speedy sleeves? Austin Healey 2
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
T REAR HUB REMOVAL Spridgets 4
JPSmit Rear Hub Question Spridgets 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
MadRiver Rear Hub Puller? Austin Healey 4
glemon Bent Rear Hub/Axle Triumph 2
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
D Left rear hub nut Austin Healey 9
D Rear Hub install Austin Healey 2
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
boxfullofyertoys Rear hub nut size Spridgets 10
B Right hand side rear hub nut Austin Healey 3
dklawson Spitfire Spitfire MkIV - Rear Hub Questions Triumph 4
M MGB MGB Banjo Rear Hub re and re wire wheels MG 0
ncbugeye Oil from rear hub Spridgets 3
