Rear hub seal speedy sleeves?
Barryp
Anybody hear install these on a big Healey?
My Rear hub sealing surfaces look like they could benefit from a set.
They appear to be readily available and a common fix for the Spridgets, but I haven't found a part # or source for the big Healey
Thanks,
Barry
mwagon
British Car Specialists- Norm Nock show the Timken brand "Redisleeve" in their catalog for Hubs etc. You can also go to the SKF Bearing website to determine what size you need for the "Speedisleeve". My local Carquest parts store said they can order any size I need.
pan
Fitted Speedisleeves to my BN1 four stud axle about 12 months ago. Working well!
W Rear Axle Hub Seal Austin Healey 8
drooartz Rear wheel hub oil seal Spridgets 6
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
D BT7 Brake Overhaul and rear hub seal replacement Austin Healey 4
drooartz Rear hub oil seal removal Spridgets 4
RedTR3 TR2/3/3A TR3 Rear Hub Seal Triumph 7
Sarastro Leaky rear hub seal Spridgets 10
tahoe healey Rear Hub Seal Austin Healey 9
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
W Rear Hub Reassembly Austin Healey 7
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
Rob Glasgow Rear Hub Nuts Austin Healey 11
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
P TR2/3/3A Rear axle hub dis-assembly Triumph 1
Lin Rear Axle Hub Nuts Austin Healey 3
J TR2/3/3A Hole in Rear Hub Triumph 7
K Rear Hub Re-assembly Austin Healey 4
KVH General TR Rear Hub Backing Plate Triumph 1
Jim_Gruber A Victory to report over those bastard Rear Drum Circlips for Bugsy IV/Hub rubbing Spridgets 3
K TR2/3/3A Rear axle hub removal? Triumph 8
G Loose lugs on rear hub Austin Healey 7
KVH TR4/4A Here'a Another Rear Axle Hub Question/Problem Triumph 7
T TR2/3/3A Rear Hub Stud Removal Triumph 4
AngliaGT TR6 Need a Rear Hub Triumph 1
C Rear Hub Removal - How Do I? Austin Healey 8
D Rear hub confusion Austin Healey 5
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
B Spitfire advice on rear axle/hub Triumph 4
TulsaFred Rear hub oil seals and bearings Spridgets 7
B Rear Hub Extension Studs Austin Healey 22
J Rear Hub/Bearing Question Spridgets 4
PHerder Rear Hub Removal??? Spridgets 10
Dougal BN1 rear hub markings Austin Healey 3
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
R Spitfire Spitfire - Rear Hub disassembly help! Triumph 2
pkmh Removing Rear Hub on BJ8 Austin Healey 48
T REAR HUB REMOVAL Spridgets 4
JPSmit Rear Hub Question Spridgets 2
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
Lin Rear Hub Extension Nuts: Attention Rich Berman Austin Healey 23
MadRiver Rear Hub Puller? Austin Healey 4
glemon Bent Rear Hub/Axle Triumph 2
D Left rear hub nut Austin Healey 9
D Rear Hub install Austin Healey 2
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
dklawson Spitfire Spitfire - Rear Hub Bearing & Axle Assembly Steps? Triumph 17
boxfullofyertoys Rear hub nut size Spridgets 10
