Willie_P
Hi,
the below applies to a '62 TR4
After a multi-year restoration adventure, I am finally at the stage of sending off my complete body tub to be painted. I would like some advice on pricing only (pls refrain from other comments if possible so as to keep on subject). here is my goal/plan/price quote:
goal: show quality paint job wherein the car leaves my house via trailer supplied by paint/body man and it returns completely refinished via trailer (and/or the paint man trailers the rolling chassis to his shop for final fitment) and able to be mounted onto fully restored rolling chassis (which is already complete, the rolling chassis that is).
add-ons (no comments here please...ha, ha): going with a partially stripped "race" interior so, floor, inner rockers, rear false-seats area and trunk need to be fully finished in exterior color. windscreen chopped/sectioned 2.5 inches, body-color undercoating applied to wheel wells and body underside. chrome body strips (between fenders and body tub) sanded and painted to match exterior color.
plan to repair/refinish:
my quote as of july 2013 from a custom shop specializing in cars that have appeared in several magazines (hot rods mostly) and has recently completed a "best of show TR4" - is $18,000 picked-up/delivered including tax.
basic question - fair price for everything noted above? I really appreciate all of your help as this is a significant amount of money for me and as we all know these cars are not going to likely command the total amount of money you have in the restoration. I am fine with that as I am probably going to keep the car for many years and do want it to look great. I just want to be sure the quote is market correct for the level of service I am receiving. thanks, wp
- bare metal stripping of entire body tub and all panels
- car has been zeibarted since the 1980's and all nooks/crannies are filled with "gunk" as well as all underlying surfaces, inner fenders - all need to be stripped (and this particular bodyman does not believe in chemical dip, etc)...wants to use heat/scraping.
- lower/rear portions of each front fender need replacement panels welded to repair typical rust as do "soup can" sized holes in same section of rocker sill (leading/front edge, just the surface section not the upper or lower pressed curves of rocker sill)
- there is no other major rust repair, etc to speak of
- as mentioned, complete refinish in single exterior/interior color with undercoat in same color
- trial fitment, final fitment to be completed by body shop
