Normal Temp and Voltage Stabilizer
MikeH
Hi All, What number does the N on the temperature gauge represent, 180? Also, where the heck is the voltage stabilizer in my 71 MGB? Thanks, Mike
71 MGB OD & Wires
63 TR4 Surrey Top
PAUL161
Mike, Look on the fire wall above the clutch pedal. It's held on with one screw and should have three wires going to it. I'm not sure what the temp numbers are at Normal on the gauge. PJ
jlaird
Not sure about temp gage either. However, my new sprite, back when in Hawaii, always ran in the 180 range except for the big passes, then it would go up 10 degrees or so, if that helps any at all.
Might want to fit a gage with real numbers under the dash for awile and see whats really happening. Just tape it under there.
At one time I ran an oil temp gage with the sender in the oil drain hole, worked fine.
wkilleffer
I've had to deal with the stabilizer. It's a very small rectangular box mounted high on the firewall behind the tach. It has three terminals, one of which will be for input and the other two are outputs to the gauges.
As far as temp goes, I use a 190 thermostat, and my gauge typically goes up to just to the right of center, obscuring the right side of the N. Sometimes it allows to whole N to be seen, but doesn't get hotter. Before I got the stabilizer to work, it would go all the way to H.
dklawson
On the Smiths 90 angular degrees of sweep gauges where "N" is straight down (or up on some later Triumphs and Jags)this corresponds to about 185oF. Keep in mind that variations between voltage stabilizers, sending units, and gauge calibrations make this "relative". Don't count on it being any more accurate than about +/- 5 degrees.
David_DuBois
Mike - Use some zip cord (power cord for lamps) and make up an extension for the wire going to the temperature sensor and for ground, then remove the sensor from the head, hook it up to the extension cord and place it in a pan of water on a camp stove next to the car. Stick a thermometer in the water and heat the whole mess up. Note the temperature when the gauge reads mid scale, or better note the gauge reading at 180°, 190° and 212°. Cheers - Dave
PAUL161
There has been a lot of discussions about the voltage stabilizer on our cars. I being the courious type, took one apart just to see what made it tic. I works by using a bi metal strip which senses voltage change in the control wire. Thus opening and closing a set of points. The points will get dirty and also burn to the point that they will stick or make no contact at all. A new sensor is fairly cheap to buy. Buy a new one from Moss or whoever and replace it. Throw the old one in the trash. Now that you have the voltage corrected, look elseware if you still have a problem. I went through the same thing and a new senser solved my problem. PJ /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/thumbsup.gif
Mickey Richaud
danmas
[ QUOTE ]
... you can convert to a solid state 10V voltage stabilizer...
[/ QUOTE ]
You can do this, and it'll work OK, but you'll be giving up a bit of accuracy if you do. The problem with the solid state regulators is that they are temperature compensated; the stock regulators are NOT. Temperature compensation sounds like a good thing untill you realize that the gauges themselves are not compensated. When the gauges are cold, it takes more voltage to operate them. When it is cold, the regulator provides more voltage, exactly in proportion to the extra voltage needed by the gauges. Both devices are of a thermal/bi-metallic strip construction, so temperature changes effect each in a complementary manner.
Mickey Richaud
Thanks, Dan - didn't realize that temperature would affect this. Is it only cold weather? We rarely take the B out when it's below freezing.
Mickey
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
I What is a normal engine temp for Bugeye? Spridgets 6
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
J Normal Engine Temp for bugeye Spridgets 1
jerrybny TR6 Normal running temp for TR6 Triumph 13
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
C Is this normal? Austin Healey 7
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
B TR2/3/3A normal oil pressure in TR3 Triumph 6
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
richie TR4/4A How much oil is normal.. Triumph 6
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
drooartz Is this normal -- top frame when folded MG 9
T Normal/good OHM resistance through spark plug wire Triumph 17
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
M "Normal" engine operating temperature. Spridgets 25
T How much dashpot oil leakage is normal Triumph 14
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
Thor What's a normal oil pressure Spridgets 3
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
B What is the "normal" operating temperature? Austin Healey 25
