Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
When I start it, and the engine is cold, the oil pressure is at ~60psi at idle, but when the engine warms up, it drops to ~23psi at idle. I'm using 10W-30 oil. Is this normal? It seems a little low.
[ QUOTE ]
I like bossing the younger guys around without giving a reason why
[/ QUOTE ]
That's okay until he gets married, then it will be HER job.
Webb - That oil pressure sounds normal for the weight oil you are using. As noted, for the climate you drive in 20W50 is a more likely choice and will raise your pressure a bit.
According to the operating manual - oil pressure at 2000 rpm under normal op cond should be 45-65 lbs/sqin. I agree with the others try 20/50 oil as it will resist heat. Be careful not to run the heavier grade oil in cool/cold regions.
Yes, the oil pressure raises signifigantly (back to about 55-60) when any throttle is given at all. Well thats good news. I sure didn't want to hear that my engine is seriously messed up!
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
