well, Mom is home and doing as well as can be expected. She came through surgery in great shape BUT was smoking the next day. I can't do anything so I'll just carry on.
I have a continual problem with my 73 BGT. I am lossing water through the overflow tube attached to the radiator. I had to change the water pump when I got the car and I now am wondering if the pump was from a 3 main engine and id the problem? No water in oil, no oil in water, car runs great, no water out tail pipe. I have not done a bleed down compression check to see if the head gasket is bad and allowing compression to leak into the water system. I have changed the head and it was magnafluxed. No cracks. No visible water outside the engine. New radiator cap in the correct poundage. Any suggestions????
/ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/thirsty.gif
