TR2/3/3A Normal TR3 Oil Pressure?
Dougs_LBC
After sitting for many months, the TR3 is back on the road, but I'm concerned...
The oil pressure is reading what I fear is abnormal @ 70-80 whether I'm accelerating or cruising at 2000 rpm's. It drops to about 55 at idle. I recently inherited the TR3 from my father, and don't remember the pressure reading that high in the past.
I just changed the oil and filter, and put Castrol 20w-50 back in it.
Is this pressure range normal? What is?
Thanks in advance!
NickMorgan
That sounds much like mine. I think it is a sign of a healthy engine and your bypass valve is doing its job, too.
Dougs_LBC
Thanks for helping me out with this question. It's apparent that I need to find a service manual as I know a number of these questions will be cropping up over time.
I'm just glad the oil pressure in the normal range.
Now, for that leaking rear main seal....
NickMorgan
That's quite normal too!!!
B TR2/3/3A normal oil pressure in TR3 Triumph 6
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
C Is this normal? Austin Healey 7
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
richie TR4/4A How much oil is normal.. Triumph 6
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
drooartz Is this normal -- top frame when folded MG 9
T Normal/good OHM resistance through spark plug wire Triumph 17
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
I What is a normal engine temp for Bugeye? Spridgets 6
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
M "Normal" engine operating temperature. Spridgets 25
T How much dashpot oil leakage is normal Triumph 14
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
J Normal Engine Temp for bugeye Spridgets 1
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
M Normal Temp and Voltage Stabilizer MG 9
jerrybny TR6 Normal running temp for TR6 Triumph 13
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
Thor What's a normal oil pressure Spridgets 3
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
B What is the "normal" operating temperature? Austin Healey 25
