Is this normal?
Chet Zerlin
Hi all!
Trying to diagnose a noise coming from my right rear brake area so I put my car up on a lift. The tire spins freely with no grinding or other noise coming from the hub so the bearing seems to be ok. There also is no lateral movement when I hold the tire on the top and bottom and push or pull either side.
When I spin the left rear wheel the right rear wheel moves in the opposite direction and I can see the drive shaft moving in a complete rotation which I think is normal. However when I spin the right rear wheel while the left wheel moves in the opposite direction the drive shaft rotates a little, then returns to the original location. It does not competely rotate when I spin the right rear wheel like it did when I spin the left rear wheel.
Is this normal? Or does this indicate an issue?
Thanks!
Chet
elrey
That appears normal. When does the sound occur, is it constant or intermittent, and can you possibly describe the sound? [Rattling, clicking, grinding, screeching, whining, singing or, perish the thought, unearthly evil laughter?]
C
Chet Zerlin
LOL - Evil laughter for sure!
Well...it sounds like a "clugging" noise if that makes any sense - It happens when I lift off the throttle, or when I push on the brakes. It does not happen on acceleration....
Chet
Bob McElwee
Check for bad wheel splins or wheel. Make sure the wheel is tight also.
roscoe
All good suggestions and I will add checking all of the bolts that retain your shock absorbers. I've had one become a little "untight" and was able to hear some intermittant clunking. The U joints would likley make a noise if worn when coming on or off the brakes, accelerating or decelerating but not so much in steady state. When I first put my car on the road I came close to having a wheel depart becuse I got interrupted while installing one and failed to tighten the knock-off. A week later, I looked it over and hopped in. Lucky for me it did give me some warning clunks/rumbles and I was entering a parking lot. That was a lesson learned ( for the 100th time). As my signature says, I did it all myself and I was glad it was my error, because I get a bit less angry with me than I do if I'm paying someone else to do something and it goes south.
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
B TR2/3/3A normal oil pressure in TR3 Triumph 6
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
richie TR4/4A How much oil is normal.. Triumph 6
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
drooartz Is this normal -- top frame when folded MG 9
T Normal/good OHM resistance through spark plug wire Triumph 17
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
I What is a normal engine temp for Bugeye? Spridgets 6
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
M "Normal" engine operating temperature. Spridgets 25
T How much dashpot oil leakage is normal Triumph 14
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
J Normal Engine Temp for bugeye Spridgets 1
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
M Normal Temp and Voltage Stabilizer MG 9
jerrybny TR6 Normal running temp for TR6 Triumph 13
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
Thor What's a normal oil pressure Spridgets 3
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
B What is the "normal" operating temperature? Austin Healey 25
