Normal Engine Temp for bugeye
JohnDough
I've got a bugeye with a 1275 engine. My temp bulb sits in the cylinder head.
On the standard gauge what will be considered normal operating temp and hot?
Thanks
jlaird
Standard bugeye is 180.
I What is a normal engine temp for Bugeye? Spridgets 6
bluemiata90 TR2/3/3A Normal running temp for TR3 engine Triumph 10
M "Normal" engine operating temperature. Spridgets 25
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
warwick-steve Oil Leaks - What is normal/typical? Austin Healey 4
C Is this normal? Austin Healey 7
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
B TR2/3/3A normal oil pressure in TR3 Triumph 6
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
matmire 23d4 distributor clockwise play... normal? Spridgets 4
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
richie TR4/4A How much oil is normal.. Triumph 6
S Is this normal? Spridgets 8
Zitch TR4/4A got the Tr4 running, however.....Breather tube leak normal? Triumph 14
T TR2/3/3A Is this normal wiring on front of steering box on TR3A? Triumph 12
drooartz Is this normal -- top frame when folded MG 9
T Normal/good OHM resistance through spark plug wire Triumph 17
K 1500 Missing CORE PLUG at back of cam isit normal? Triumph 5
1 Is this normal? MG 6
RJS Is this normal? Triumph 24
T Normal for a Carter/Facet pump to be hot Triumph 11
NardisCNC Gearbox Noise in 1st!! - Is this normal?? Spridgets 13
davester Is this normal for a worn out clutch? Spridgets 2
CraigLandrum TR2/3/3A TR3 Oil pressure normal? Triumph 26
T How much dashpot oil leakage is normal Triumph 14
George Zeck 190 - 195 normal temp OK ?? Spridgets 2
Jayrz Coil is very HOT, Normal? MG 2
S Alternator Gauge- What's "Normal" Triumph 6
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
racingenglishcars Not exactly a normal car @ 115000 BHP Other Cars 5
G Spitfire Is this normal Spitfire operating temperature? Triumph 8
D TR2/3/3A Normal TR3 Oil Pressure? Triumph 5
TheAssociate Water In Oil - Normal?/Rocker Oiler Triumph 9
Baz Is this normal??? Spridgets 18
L Back to Normal--Water problem MG 16
M Normal Temp and Voltage Stabilizer MG 9
jerrybny TR6 Normal running temp for TR6 Triumph 13
A Normal rpms MG 6
J is body flexing normal? Spridgets 10
C Center-lock to "normal" wheels? Spridgets 4
G How much frame flex is normal? Triumph 8
Thor What's a normal oil pressure Spridgets 3
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
T sport or normal mode Jaguar 5
Webb Sledge TR6 What's normal oil pressure for a TR6? Triumph 7
B What is the "normal" operating temperature? Austin Healey 25
