Coil is very HOT, Normal?
Jayrz
So I have been chasing my drivability problem where my 64 MGB accelerates well and then in steady cruise after no longer accelerating,,,,, the motor will go 30 secs or so and start to caugh and miss as if running out of gas. I pull over and the idle burbles and a few seconds later is idling smooth again and i can accelerate away again until it does it,,,, again!
Anyway, checking all my connections I noticed the gold "sportcoil" is very hot to the touch. Is this normal? I don't remember coils getting hot like that.
Thanks in advance guys,
Jay
19_again
I had a similar problem after changing to a new gas cap, check to be sure your tank is vented properly. Of course the gas filter is first place to look. Still a neophyte myself, but trying to contribute.
Mike
David_DuBois
Jay - Mike is correct, the first place to look is the filler cap on your fuel tank since the early MGB vented the tank through the cap. Just remove the cap and drive for awhile to see if the problem goes away. If it does, get a new cap. If you are still having a problem see the article, Fuel Delivery Troubleshooting Guide in the SU Fuel Pump Articles section in my web site at: https://homepages.donobi.net/sufuelpumps/
As for the hot coil, make sure that you have the proper 12 volt coil and not the 6 volt coil used on the later MGBs that requires a ballast resistor in the circuit. The 12 volt coil should measure 3 ohms across the primary terminals, where the 6 volt coil is about half that amount. If the coil is correct, check that you have the proper amount of dwell or gap in the points. the points gap should be 0.015" and the dwell is 60 degrees. If the gap is less than 0.015" or the dwell is greater than 60 degrees, it will cause the coil to run hot and the drivability to go to pot.
Cheers,
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
timsgolf Coil Wiring Austin Healey 20
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
2 TR2/3/3A Coil issues Triumph 31
D coil spring finish Austin Healey 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A Rear coil springs for TR4A Triumph 4
Marla TR4/4A Pertronic coil Triumph 12
M TR4/4A TR4 front coil springs Triumph 0
M TR2/3/3A Why is my coil so hot? Triumph 6
Marvin Gruber Big healey coil springs Austin Healey 7
M Starter field coil for BN1 Austin Healey 17
KVH TR4/4A Front Coil Spring Spacers Triumph 1
S TR2/3/3A Coil wiring Triumph 4
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
JimTR4 TR4/4A Coil - easily confused... Triumph 6
T TR2/3/3A coil mounting bolt oil leak Triumph 2
2wrench TR6 What's for dinner? Fried Coil??? Triumph 4
Griz Coil Wiring Austin Healey 4
2billydavies TR2/3/3A dead battery... until i disconnect the wire from coil to distributor Triumph 10
J TR2/3/3A TR3 coil spring height Triumph 4
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
2 TR2/3/3A TR2 Coil choices Triumph 5
6 Coil Wire Terminations Spridgets 4
TulsaFred Ignition / Ignition coil problem Spridgets 10
