TR4/4A Rear coil springs for TR4A
Foura
What rating and length are members using
320lb X10" ?
Malcolm, this may help. https://www.tr-register.co.uk/forums/index.php?showtopic=29428
I have 470lb/in on the back and 390lb/in on the front, with telescopic Konis all round. I measured the ride height at all four corners after I installed them and it was high at the left front and low at the right rear. I installed a 1/2" spacer on the rear right spring and it levelled the car up nicely. Are you still going to use 250lb/in on the front with an anti-roll bar?
It depends how you intend to use the car. As you know we have been on some long trips with the two of us plus about 100lbs of luggage. (and about 10lb of oil on the last trip!). The car has been perfectly comfortable and very rarely bottoms out. As I have said on the forum before, you need to remember that both front and rear springs are mounted part way along the wishbones and trailing arms, so the wheel rate is about 2/3 of the spring rate.
M
malbaby
Thanks guys....
Experimenting in the shed ATM, ride height etc.....250lb x10" on the front with 1/2" packers
320lb x10" on the rear with 3/4" packers.
Yet to fit shockers and test drive to determine if they are too soft...[especially the rears].
T Rear Coil Springs Triumph 4
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
S front/rear coil spring diamaters. Triumph 4
B How Free / rear wheels turn - XJS & Coil Question Jaguar 0
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
