TR2/3/3A Coil wiring
Sarge
the wiring chart has "CB" and "SW" notated - which wire is which? what does that stand for? Which is positive and which is negative?
Thanks for your help !!
TFB
My guess is cb is circuit breaker for distributor - and sw is switch for +on a negative ground car.
Tom
Geo Hahn
Contact Breaker & SWitch - in my experience those designations were on coils back when most Lucas-equipped cars were positive ground.
Later, when negative ground cars came into vogue, the markings were changed to + & -.
I think you will be okay by regarding CB = + and SW = -.
martx-5
I'm not sure it makes any difference one way or the other.
Generally, it makes no difference, as most of the time it will run regardless of the how the polarity of the coil is wired. However, there is a difference in how effectively the spark jumps the electrodes in the spark plugs depending on the polarity. Read this link for a full explanation...
https://mgaguru.com/mgtech/ignition/ig104.htm
timsgolf Coil Wiring Austin Healey 20
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
Griz Coil Wiring Austin Healey 4
Y MGB 1977 MGB Ignition Coil and Wiring. MG 7
Scotsman TR2/3/3A Coil wiring Triumph 12
W TR6 tr6 74' coil wiring Triumph 2
W TR6 74' tr6 coil wiring Triumph 8
C Coil to Distributor wiring? Triumph 10
R wiring hookup for coil on BJ-7 Austin Healey 1
N Coil Wiring Austin Healey 1
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
L Spitfire Bit confused by my Spitfire coil wiring... Triumph 10
jsneddon Ignition Coil Wiring Triumph 2
B 79 Midget Coil Wiring Spridgets 18
G Ignition / Coil Wiring Question MG 12
C Coil Wiring Triumph 11
hawkwind Coil wiring Spridgets 10
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
wkilleffer MGB Coil resistance MG 4
Cokerair TR4/4A Fried Ignition Coil Triumph 18
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
F Hot Ignition Coil Austin Healey 6
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
K TR2/3/3A Front coil springs? Triumph 2
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
longbridgehealey Coil terminals Spridgets 1
P TR3B Coil Issue? Triumph 7
A Wedge Won't fire without jumper from coil to battery Triumph 6
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
JPSmit female spade tab - coil Restoration & Tools 13
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
Lin Lucas coil question Austin Healey 8
K What to do for coil bracket on upgraded generator? Austin Healey 8
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
JPSmit Daughter's VW - coil pack? Other Cars 2
S Intermotor or Lucas Sport Coil ? Austin Healey 14
FlyingCat Spitfire Spark to Coil Triumph 23
S TR2/3/3A Front coil spring recommendation? Triumph 7
S TR4/4A Coil-over suspension upgrade Triumph 4
JPSmit Bosch Coil question Spridgets 14
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
2 TR2/3/3A Coil issues Triumph 31
D coil spring finish Austin Healey 5
M TR4/4A Front coil springs.....Rating & Length? Triumph 1
M TR4/4A Rear coil springs for TR4A Triumph 4
Marla TR4/4A Pertronic coil Triumph 12
M TR4/4A TR4 front coil springs Triumph 0
