Is this Heater Control Cable broken?
2wrench
Please examine this heater control cable pic and tell
me what you think.
The outter sheath becomes disconnected as shown with the
ball point pen used as a pointer.
When the knob is pulled, the cable works fine. When the
knob is pushed in order to close or turn off the heater,
the outter sheath of the cable comes apart from the back
of the switch and, or course, the heater does not shut off.
Sounds broken. These parts are sold in pieces. Don't
want to wait to receive new pieces to find identical to
what I have.
Please copy and paste the web site address to view the pic and tell me what you think.
Thanks.
2wrench
https://i169.photobucket.com/albums/u222/2wrench/HeaterControlCable.jpg
G
Yep, it's broken. Trade you a new one for that light thingy.
You will have to get a new one. As you say, it will open, but not close. I have to close the heater valve on my head the last few millimeters (oops, for got we don't use Metric in my TR6...about last 1/4") by hand.
You can try jambing it back together and hitting it with a BFH but that might only work for a while.
2wrench
2wrench
Like to say I could make the trade, Bill, but that
wouldn't be so hot.
Did you contact Victoria British at the web site I
give ya?
The thing didn't say NA, so I'm hoping you can buy brand
new what you need. Think it was around $60.
About half the profit of a prophy, huh?
davidk
TRF has them for $31.50. Mine's been on backorder for about two months....
TRopic6
2wrench,
I inherited the same problem with my 6. I removed the whole assembly, squeezed the parts back together and ran some JB Weld around the joint. I put some greast to make life easier on the assembly. It's held for 3 years, but I admit I don't use the heat much! (just to defog during heavy rains) Hopefully the pix came out with enough detail.
The cable has to make a sharp right bend to get around the heater box, which speeds seperation of the sheath from the main control part.
Jeff
74 TR6 CF13816U
TheAssociate
2Wrench: That looks like something that could easily be brased. I would fit the parts back together and brase them, or take it to someone who can. Seems a pity to get rid of a nice original part.
Adam.
____________________________________________________________
1973 Triumph Spitfire.
Tomster
Definitely work some lithium grease in the cable sheath before reassembly.
A mini hose clamp applied around the sheath, may help the bond when you do it
KVH General Tech Heater control valve/cable Triumph 1
Stewart heater control cable lenth? MG 0
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
jhorton3 Heater Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
I TR6 69 TR6 heater control cable Triumph 6
Musicman Installing Heater Control Cable Triumph 3
R TR6 Heater control bezels TR6 Triumph 2
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
B TR6 Removing the ckoke/heater control knobs Triumph 4
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
H heater control panel and knobs Austin Healey 1
S Choke & Heater Control Knobs Triumph 2
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
W Heater Control Tap Spridgets 3
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
Steve1970 how does the heater control plinth connect? Triumph 4
58Custom Heater control valve. Suggestions? Spridgets 39
H Heater control question MG 3
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
S removing knobs from heater control etc Triumph 4
2wrench Heater control valve and spigot install Triumph 20
Dave Richards Stuck heater control lever Austin Healey 4
VelodromeRacer Leaking Heater control valve Austin Healey 5
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
Rob Glasgow Heater Control Panel Austin Healey 1
A TR6 TR6 Heater Control Question Triumph 4
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
