Heater Control Valve function
Lutz Kramer
Hi there from Germany,
I have just removed my heater from under the dashboard, overhauled everything, painted it and replaced the heater control valve. To make sure it's not leaking I then connected the inlet to a garden hose and the outlet with a pressure gauge to make sure that the water pressure doesn't exceed 1.0 bar. No matter if I open the valve or close it, water is still passing through the heater with only a little difference in the flow rate.
When I do the test with air by blowing the air into the inlet with my mouth, the valve works fine. When closed, no air passes through the valve, when open, the air passes freely. So there should be no crack in the diaphragm.
Now I would like to know if the following considerations are correct:
a) The diaphragm, which is located inside the valve and ensures that no water can flow through the valve when closed, is - as far as I remember - somehow spring-loaded and could
therefore have a bypass function???
b) Perhaps design related some water should always flow through the heater so that it does not become muddy and water bubbles cannot form???
c) Third possibility: The Heater Control Valve is defective? But it's new and not leaking?!
Would be happy to hear from you!
Lutz
Lutz Kramer
Lutz Kramer
1 bar hose pressure is probably overwhelming the rubber diaphragm. Remember the system uses 7 psi - 1/2 bar.
Steve, I believe you are right. 1.0 bar might have been to much. Breathing out with pressure creates about 0.25 bar, which seems not enough to overcome the diaphragm of the valve.
KVH General Tech Heater control valve/cable Triumph 1
H BJ8 Heater Valve/Control Tap Austin Healey 3
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
58Custom Heater control valve. Suggestions? Spridgets 39
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
2wrench Heater control valve and spigot install Triumph 20
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
VelodromeRacer Leaking Heater control valve Austin Healey 5
R TR6 Heater control bezels TR6 Triumph 2
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S Heater and fan control replacement - any advice? Austin Healey 9
B TR6 Removing the ckoke/heater control knobs Triumph 4
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
H heater control panel and knobs Austin Healey 1
S Choke & Heater Control Knobs Triumph 2
W Heater Control Tap Spridgets 3
Steve1970 how does the heater control plinth connect? Triumph 4
H Heater control question MG 3
Stewart heater control cable lenth? MG 0
S removing knobs from heater control etc Triumph 4
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
jhorton3 Heater Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
2wrench Is this Heater Control Cable broken? Triumph 6
Dave Richards Stuck heater control lever Austin Healey 4
I TR6 69 TR6 heater control cable Triumph 6
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Musicman Installing Heater Control Cable Triumph 3
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
Rob Glasgow Heater Control Panel Austin Healey 1
A TR6 TR6 Heater Control Question Triumph 4
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
