TR6 Fuel line and Foley catheter blockage
pdplot
Someone posted here recently about an intermittent fuel problem. The car would go for a time, then stop and eventually resume, only to keep repeating. I just got out of the hospital after 7 days caused by complications from a kidney stone. I was fitted with a catheter ( don't ask me to go through it again) and sent home with 2 stents in place and the stone still there awaiting further surgery to remove. Without going into the gory details, I underwent 36 hours of excruciating pain caused by the catheter being blocked by blood clots. Apparently despite the clog, some fluid did get through thus temporarily relieving the pain. I was too stupid to realize there was a problem - just though that was the way it was, not realizing that the catheter was supposed to drain 24/7. Now there is absolutely no difference between a fuel line and your urinary tract. This isn't rocket science. I'm convinced that the poster's fuel problem was the same as my catheter drain - enough fuel would sneak through to run for a short time at which point the filter would clog again and the cycle would be repeated. I have to go back in next week to get the stone out for good.
mrv8q
BTDT, exact same circumstances, 25 years ago. Now I understand the miracle of morphine!
Best of luck on your recovery!
P
pdplot
Thanks, guys. My operation is scheduled for March 25th. I can't tolerate morphine, codeine, etc. It's Tylenol or nothing...
GTP1960
I take it your stone(s) were to tough for ESWL or laser to bust?
PD, That does not sound fun at all.
i take it your Urologist is going to do it the old fashion way (percutaneous)?
or are you going to let them have another go at you with the ureteroscope?
Bless you PD. Hope all goes well this time!
P
pdplot
scope and laser. It's way down and lodged kinda sideways 5 x 8 mm. According to the doc, its been in there a l-o-n-g time.
On the whole, I'd rather be laying under a Triumph looking for a grease fitting...
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
C TR4/4A Fuel line question..... Triumph 3
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
M Fuel Line Assistance Needed Spridgets 5
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
M BN1 carburetor fuel line Austin Healey 9
V TR2/3/3A TR-3B Fuel Line Question Triumph 7
E TR4/4A TR$ Fuel line from tank Triumph 13
H TR5/TR250 Fuel line route Triumph 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
T TR2/3/3A Fuel line heat shield Triumph 39
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
K TR2/3/3A Copper fuel line..... Triumph 6
M TR4/4A Exhaust/ Fuel line? Triumph 8
J 1/4" BSPP Fuel Line Connection, Hose from Steel Line to Carb Austin Healey 2
J Fitting 5/16" Steel to 5/16" Braided SS Rubber Fuel Line Austin Healey 4
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
