TR4/4A Exhaust/ Fuel line?
mtlman8
I was doing some work on my exhaust over the weekend and I discovered that the metal fuel line runs along the exhaust and touches in some places. Is this something to worry about? Makes me a little nervous.
TR3driver
Great Pumpkin - R.I.P
Definitely sounds like an OOPS to me. You really don't want to have the fuel boiling in the lines.
charleyf
John,
i have two TR4's and the fuel lines like the TR3 runs up the left or driver's side of the car. The only thing near the exhaust is the speedo cable on the right side of the car. I am sure that the outlet on the fuel tank is on the driver's side as well as the fuel pump. Hard to understand why somebody would alter it that way.
Or might the location of your problem be at the rear of the car that might have a dual exhaust?
Charley
HerronScott
John,
Charley
Charley,
John has a TR4A which has a different frame and fuel pipe routing than the TR4 due to those differences (through the center where the exhaust passes). But seems like either the fuel line would have to be either away from the frame or the exhaust would have to be too close to the frame for this to happen.
Scott
charleyf
Charley,
Scott
Scott,
So which side does the fuel line run on your TR4A's? I am well aware of the different IRS frame but the fuel tank and fuel pump are still both on the left side of the car, while the exhaust is on the right side of the engine.
Charley
JerryVV
On a TR4A IRS the brake and fuel lines run up the left frame rail, my guess is that a solid axle car would be he same. The exhaust runs down the center close to the driveshaft and then splits for the dual system. Not certain how it connects to a single system with the cross muffler, never looked closely at those.
M
mtlman8
The fuel line on the IRS runs next to the brake line. The problem is, when the exhaust splits at the Y the fuel line is touching the exhaust. I was able to bend it a little. Now it sits about an inch away. That still makes me uncomfortable. Is an inch enough? Otherwise I was thinking of running a new line on the outside of the frame.
TR3driver
With only an inch, I'd want some sort of radiant heat shield between them. Especially in Phoenix. Note that you don't want the brake line touching the exhaust either.
M
mtlman8
The PO must have done something, because the brake line runs nice and straight along the frame. The fuel line arcs, curves and runs in a real odd way when it comes out of the frame and into the "tunnel" before exiting and going to the tank.
CinneaghTR TR4/4A TR4A Fuel and Brake Line Routing and Dual Exhaust Triumph 6
TEM666666 Exhaust loud popping: Lean? Rich? Fuel? What else? Spridgets 25
J Fuel leak onto exhaust manifold - Help! Austin Healey 3
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
