TR2/3/3A Can heat from exhaust downpipe .....
CJD
Heat is not good for anything electrical, but our starters live a long time. The worst I have seen are header installations, where the starter is wrapped in exhaust pipes...and they still seem to live.
TomMull
Ditto, both my TR3s have original starters.
E BJ8 Seats, Exhaust Hanger, Heat Shield Locations in Floor Austin Healey 7
H The heat shield for the Longbridge between the exhaust manifold and carbs Austin Healey 1
J Side exhaust heat shield Austin Healey 23
19_again MGB MGB exhaust heat shield MG 3
R Exhaust Heat Shield Austin Healey 3
L remove heat wrap on exhaust? MG 6
HealeyPassion Reducing Muffler Heat Austin Healey 2
steveg Heat Shields Austin Healey 17
V heat shield Triumph Classifieds 7
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
M Heat-related carb issue on BN1 Austin Healey 7
EWD TR6 ā€˜74 TR6 Interior - Padded dash and heat/sound material Triumph 4
AH67 Heat Shield finish 66 Type Jaguar 5
J Bj8 intake manifold to heat shield to carb gaskets Austin Healey 4
BLong63AH Moss Supplemental Heat Shield Austin Healey 2
K TR2/3/3A Revington alternator heat shield. Triumph 0
60TR3A Is It Safe to Heat My Garage All Winter While I Am In Florida? Austin Healey 34
K TR2/3/3A DIY Alternator heat shield>>> Triumph 2
L 100/ Moss Heat Shield Austin Healey 2
wangdango Keeping the heat out? Austin Healey 11
DornTRoriginal TR2/3/3A Heat Shield Issues Triumph 6
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
GTP1960 TR2/3/3A Carb. Heat shield location? Triumph 11
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
T TR2/3/3A Fuel line heat shield Triumph 39
NutmegCT heat valve control cable Other Cars 0
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
69mgbgt No cabin heat in my 1997 jaguar xj-6 Jaguar 1
I Spitfire If you can't stand the heat.... Triumph 7
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Heat shield for tranny cover Triumph 4
R Heat Shield Detail Austin Healey 3
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
T General TR heat proofing floor boards Triumph 10
R Heat shields and other hot topics Austin Healey 36
tahoe healey Dynamat heat shield Austin Healey 8
R securing heat shields Austin Healey 11
KVH Carb Heat Shield Installation Triumph 2
D Carb Heat Shield Spridgets 12
HealeyDave Intake manifold heat shield fitting issue Austin Healey 2
NutmegCT heat barrier Restoration & Tools 3
NutmegCT TR2/3/3A TR3 cockpit - summer heat! Triumph 12
M Supercharge Heat Sheild Question [pics] Triumph 3
Russ Austin Heat ah at least warmth. Triumph 11
R TR4/4A Tr4a, alternator heat shield Triumph 9
E Asbestos heat shielding. Austin Healey 8
R Need more heat - which thermostat MG 15
J T-Series electrical heat and smoke from the switch MG 4
G HEAT SHIELD! Austin Healey 10
R No Heat Shield Cause Dieseling? MG 1
