Spitfire If you can't stand the heat....
ichthos
Trying to get a friend to join the forum. In the mean time, he had a question. He owns a spitfire but says it is not all that pleasant to drive in the summer because it gets so darn hot. Haven't seen his car in person, but what are the reason his car would be generating so much heat? And yes, he has the heater tuned off.
Kevin
toysrrus
Kevin,
Is the car "Overheating" or simply generating heat from the "Engine & Trans. into the "Cockpit"?
He may try insulating the Trans cover, Floorboards & Footwells with something like "Duramat" or the like to help keep out the heat; If its simply generating heat.
Russ
dklawson
As Russ said, it is quite likely to be from the engine heat. A layer of insulation on the floor and transmission tunnel/cover can make a big difference.
Rhodyspit75
Put a bright light under the closed bonnet when it's dark. You will be able to see all the little spots in the firewall that get hot air forced through them into the cockpit. Plug those holes and as others have said insulate the tunnel and firewall.
Spock
When I first got my TR6 I had exactly the same impression, but in my case it turned out to be a broken heater cable. I could pull the knob on the dash out to turn the heat on and push the knob back in to keep the heat on. Kept wondering why it was so hot with the knob pushed in.
Worth the effort to look under the hood and make sure the valve is being opened/closed in response to the knob movement. I ended up replacing the cable and am currently in the process of replacing the valve (too stiff, causes cables to fail).
rikiwho123
Hi all i've had this problem with my spitfire and added insulation from eastwood which helped but it still got hot so i tried rerouting the heater hose so it didn't have to run through the interior heater and now i'm in the cool no more hot interior and i really don't need a heater because this is my toy and only gets driven in nice weather.
Don_R
I keep the heater off and put the vent control on heat instead of defrost...lets the outside air go throught the heater box and onto the floor....
also insulated the aftermarket trans tunnel when i installed it......
Trevor Triumph
I replaced the cardboard transmission cover with an ABS plastic unit and added insulation. The insulation plus the carpet seems to help. Before I rebuilt the other Spitfire, I wondered why my wife complained about her feet getting so hot. Then I saw that the broken cover let the heat from the radiator and the exhaust manifold flow right onto her feet. It was not so bad in January but overwhelming in July.
John
J For Sale Hoist and engine stand Triumph Classifieds 0
M Engine Stand for 3000 Motor Austin Healey 7
A Making an A-series engine stand adaptor fitting Spridgets 2
steveg Harbor Freight jack stand recall Austin Healey 7
Rob Glasgow Hardtop Stand Austin Healey 9
L Wanted Engine stand adapter Austin Healey Classifieds 4
J Mounting 3000 engine to stand Austin Healey 7
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
P TR2/3/3A Wetliner in a engine stand, how? Triumph 4
A Engine stand rotisserie plans Austin Healey 12
KVH TR4/4A Using the Engine Stand Triumph 3
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
Jeepster NEC classic car show UK - 3 works Healey 3000s on AH club stand Austin Healey 20
R correct jack stand placement. Austin Healey 26
T Engine stand Austin Healey 2
pkmh Interesting little jack stand discovery, "Drednaut" Austin Healey 0
Hap Waldrop GT6 Triumph 6 cylinder side engine stand adapter Triumph 13
V Engine Stand XK150 What works? Jaguar 5
T Engine test stand Austin Healey 8
5 Would the real OEW shade please stand up Austin Healey 13
jlaird Mike Miller please stand up. Spridgets 4
J Engine stand adaptor specs or diagram? Spridgets 7
TulsaFred Engine test run stand Spridgets 10
S T-Series How do we mount a TD engine on an engine stand? MG 7
J Engine Test Stand Restoration & Tools 7
B engine stand Austin Healey 15
T Engine stand 101 Triumph 14
jaegzie Searched, no luck...What does HP on cars stand for Spridgets 20
T Engine stand recommendations Triumph 14
lbc_newbie Engine stand bolt sizes Spridgets 1
Gray_Cat Engine Stand Rotisserie Spridgets 4
S Healey jacking points and jack stand placement Austin Healey 13
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
J Harbor Frieght Engine Stand? Triumph 0
J Harbor Frieght Engine Stand? Restoration & Tools 15
JPSmit Engine Stand Spridgets 0
Trevor Jessie Nice engine test stand Spridgets 7
PHerder Tequila Brad's engine stand LIVES!!! Spridgets 0
L Engine stand: how do you attach? Spridgets 12
tony barnhill Jack Stand Sale Restoration & Tools 26
B Engine Stand Adapter Spridgets 2
ChrisS Free [almost] A Series Stand Adapter Spridgets 4
Tinkerman TR2/3/3A How to build an engine run in stand for 60 TR3 Triumph 9
drooartz Engine stand/dolly Spridgets 20
frankenstang57 1500 on a stand? Triumph 8
Tinkerman TR2/3/3A Engine Stand 60 TR3 Triumph 1
Jarhead 'B' body stand MG 9
weewillie engine stand Restoration & Tools 12
ChrisS KB / Engine Stand Spridgets 4
JPSmit Engine Stand Question Spridgets 26
