Engine Stand XK150 What works?
vettedog72
Im going to start a build of a '59 XK engine and need to know what engine stand/s are ok for the process. I am thinking to assemble the engine and transmission on the stand and transfer the unit into the car when complete. It was awful heavy when I pulled it but that was a long time ago. Ill rent the hoist when it goes back together but want to buy the stand. Any advise is appreciated.
LarryK
I've only seen custom built engine stands for the Jaguar and all of them built by the people working on them. Every stand I saw was equipped with radiator and gauges for test running before installing. I would say I've seen 5 in all and they were pretty ingenious in design. Might search for engine stands and see what comes up.
I bought a XK140 a couple of years ago. Engine and trans were on a homemade stand, I still have that stand. You're welcome to it. I'm about a 5 hour drive from you. PM me if interested
Marv
MikeP
I've seen pictures of custom stands that look like a minature rotisserie. Bolt to the engine mounts in front and the bellhousing flange in the back so as to avoid a large weight cantilevered off it. Probably could mahe one with two regular stands.
V
vettedog72
Marvin, thanks for your offer. I am looking for a stand that will allow the engine to be positioned pan-up or head up or even side up, etc so I can really "get to it" during the rebuild. The engine is currently disassembled and I need to put it back together. Because the engine is so long compared to modern V8's (with out the transmission being attached) I just wondered if any body with experience would recommend a engine stand that is sturdy and not likely to tip over. Does your stand allow the rotation of the engine?
J For Sale Hoist and engine stand Triumph Classifieds 0
M Engine Stand for 3000 Motor Austin Healey 7
A Making an A-series engine stand adaptor fitting Spridgets 2
L Wanted Engine stand adapter Austin Healey Classifieds 4
J Mounting 3000 engine to stand Austin Healey 7
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
P TR2/3/3A Wetliner in a engine stand, how? Triumph 4
A Engine stand rotisserie plans Austin Healey 12
KVH TR4/4A Using the Engine Stand Triumph 3
2billydavies TR2/3/3A what bolts should i use to mount engine on an engine stand? Triumph 13
T Engine stand Austin Healey 2
Hap Waldrop GT6 Triumph 6 cylinder side engine stand adapter Triumph 13
T Engine test stand Austin Healey 8
J Engine stand adaptor specs or diagram? Spridgets 7
TulsaFred Engine test run stand Spridgets 10
S T-Series How do we mount a TD engine on an engine stand? MG 7
J Engine Test Stand Restoration & Tools 7
B engine stand Austin Healey 15
T Engine stand 101 Triumph 14
T Engine stand recommendations Triumph 14
lbc_newbie Engine stand bolt sizes Spridgets 1
Gray_Cat Engine Stand Rotisserie Spridgets 4
J TR6 best way to mount the TR6 on an engine stand? Triumph 3
J Harbor Frieght Engine Stand? Triumph 0
J Harbor Frieght Engine Stand? Restoration & Tools 15
JPSmit Engine Stand Spridgets 0
Trevor Jessie Nice engine test stand Spridgets 7
PHerder Tequila Brad's engine stand LIVES!!! Spridgets 0
L Engine stand: how do you attach? Spridgets 12
B Engine Stand Adapter Spridgets 2
Tinkerman TR2/3/3A How to build an engine run in stand for 60 TR3 Triumph 9
drooartz Engine stand/dolly Spridgets 20
Tinkerman TR2/3/3A Engine Stand 60 TR3 Triumph 1
weewillie engine stand Restoration & Tools 12
ChrisS KB / Engine Stand Spridgets 4
JPSmit Engine Stand Question Spridgets 26
timbn2 engine securing points to engine stand??? Austin Healey 18
C TR2/3/3A Tr3 Engine Stand Question Triumph 3
Ohiobugeye 948 cc on An Engine Stand Spridgets 17
pa297pass 6 Cylinder on an Engine Stand Triumph 4
J Engine Stand Mounting Austin Healey 7
klutterbutt 1275 on an engine stand MG 14
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
