Fuel leak onto exhaust manifold - Help!
James_B
Hi all,
I'm new to Healeys having bought my first car, a 3000 Mk1, a few weeks ago.
It is one of the cars with the electronically operated auxilliary enrichment carburetor that was discontinued.
While tweaking the main carbs this afternoon I noticed that, while idling, periodically significant amounts of neat fuel were being 'blown' out of the air intake straight onto the exhaust manifold. I'd estimate 10ml of fuel would pour out each time and it would reoccur every 2 minutes or so.
The unit is no longer activated by water temperature, rather a switch on the dash. The choke was off at the time.
I'm now very nervous to drive the car but have no idea where to start. If any one has any experience of this issue I'd be most grateful for any guidance.
Many thanks,
James
Keoke
Set the electric choke back up like it is designed to be. Sounds like it is runing too rich.
J
James_B
Thanks for the advice. I'll probably do that in due course but given that it is a switched device I'm pretty sure it won't make any difference to the fuelling issue?
You are correct about the richness - you need to run the car extremely rich for it to drive anywhere near properly, the downside is that hot idle is dreadful with iut constantly trying to quit. I set the timing and tuned the carbs down to about 4% CO (the lowest I achieve before running out of adjustment). The idle was then lovely but the car became virtually undriveable due to misfires below 2500rpm - I had to drive it like a racing car to get anywhere!
It was when i put it back to how I found it that i noticed the fuel leak. My guess is that the solenoid is not closing the system fully and allowing the thermocarb to pass fuel into the induction manifold. That said I'm not sure that would explain why the car misfires when tuned "properly"...
J
James_B
Having stripped the carbs I've discovered that it was a sticky float valve in the rear carb. The thermocarb's intake is lower than the float chamber overspill surprisingly.
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
J Bugye Fuel Tank Leak Austin Healey 4
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
bugedd Fuel Leak and Proper Routing Spridgets 9
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
J Had a fuel leak back by the pump! Austin Healey 0
E Fuel leak Austin Healey 3
DNK Fuel Pump Leak Triumph 9
bill_powell HIF6 Fuel Leak? Spridgets 5
Stinger TR4/4A TR4A Fuel Pump Leak Triumph 6
MCNX_BFF Wedge TR7 brake fluid leak--bonus: fuel leak, too! Triumph 9
Steve1970 this just in: wife not crazy, fuel leak was real! Triumph 27
S Fuel Leak / Smell Triumph 7
tahoe healey Fuel pump leak Austin Healey 6
Dadandson Fuel Leak or maybe burp? Spridgets 4
Wana Fuel leak Austin Healey 6
jlaird Sat morning fuel leak test Spridgets 3
GregW Dag nabbit, fuel leak Austin Healey 21
Tullamore TR6 TR6 Fuel Leak Triumph 4
S Help! Stromberg fuel leak Triumph 3
D TR2/3/3A TR3 Fuel Shutoff leak Triumph 4
S Re: the use of plumbing 0-rings for fuel leak Triumph 6
Hegg Excessive Fuel Pressure - how do I stop the leak? Triumph 8
bighly Fuel level sending unit leak Austin Healey 1
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
