MGB Front Wheel Bearings. Re-grease or replace?
joelodom
Hello! I'm still shaking down my 1970 MGB that I bought from Dad. One local enthusiast said I should re-grease the front wheel bearings (who knows when that was last done). I'm doing some research on that and I'm trying to decide if I should re-grease them or just replace them while I'm at it. I found some instructions on their replacement, but nothing on just re-greasing. How much more difficult is it to replace them than to clean and grease them? Replacing them requires quite a bit of disassembly from what I see, and I'm not very mechanical (yet) -- but it looks like I have to remove them to re-grease them, anyway? Any advice? Thanks!
Mickey Richaud
They do have to come out regardless. ~$40 for new bearings and seals will do it.
BobHaskell
I'm not that familiar with the '70 MGB; ours is a '80. The bearing arrangement in ours is the same as the big Healeys. There's a distance piece and some shims between the inner and outer bearings that set the bearing preload. If you change the bearings, then you may need to change the shims installed. They come in various thicknesses: 0.003", 0.005", 0.010" and 0.025". For the Healeys, you try to get about 0.002" free play; with the MG you shoot for 0.000". Don't know why they're different. The workshop manual covers the adjustment.
Joe Reed
Whether you replace them or repack/reuse the ones you have the process is the same......disassemble, pack the bearings, reassemble. New wheel bearings don't come pre-greased., so there really is no difference at all in the process. If you just service the ones you have the shims should still be within spec. If you use new ones, you may need to change the shim stack to keep them in spec.
This is, of course, unless you don't use the shim method and just install them using the no-shim method - just adjusting them like an old fashioned American car. It's always a huge debate on which method is correct, appropriate, necessary or safe. Needless to say, thousands of these cars are our there successfully doing it both ways.
Personally, my preference would be to inspect the old bearings and races and reuse them unless they looked suspect.
mctriumph
The original bearings were Timken DO NOT use any bearing from China. Clean the old bearings and
inspect them for any pitting or wear .If OK , repack with Amaloid red. It far exceeds you needs.
If they are NFG (nofreakingood) get Timken or the Japanese equal.
The red grease was what we used on the racer for 8 years with wheel bearings lasting 3 seasons!!
Mad dog
YakkoWarner
Can someone clarify for me what the whole shim-stack system is about on these? I expect I will need to be visiting this job on mine (hopefully not years from now) and I'd like to be able to do it correctly - but all I have ever touched was the standard US style bearings in a heavy duty GM vehicle...
BobHaskell
It's covered in the workshop manual.
If playing with the shims, I oil the bearings and don't install the inboard seal. Install the inner bearing on the axle. Slip on the hub. The distance piece sits against the inner bearing's inner race. The shims go in next, followed by the outer bearing. I start with too many shims. Then the heavy washer and the castelated nut. I made a nut that sticks out of the hub. Use a test indicator with a magnetic base to measure the slop. The magnetic base sticks to the brake rotor and the indicator point sits on the nut. Push the hub in/out and read the distance the hub moves on the indicator. Adjust the shims accordingly. If the indicator says there's 0.010" play, I might only reduce the thickness of the shims by 0.008". Sneaking up on it. The hub should rotate freely with no noticeable play when you push/pull on the hub. When you're happy with the shims, take it apart, grease the bearings, set the inner bearing in the hub and install the seal. Put it back together.
J
joelodom
Thanks, all. I've taken notes on this advice and am studying the workshop manual. I can do this! If anyone has more advice, I'm all ears.
Platinum
A "kit" of three or four of the various thickness shims ahead of time can make a big difference in how long the job can take if you have to replace bearings. If replacement is necessary, use Timken (even though some of those have been marked "Made in China" or other places lately). Timken conveniently still uses "Set 2" and "Set 6" for the outer and inner part number designations. They are "standard" sets and even RockAuto has 'em.
And the dial indicator setup can be problematic if you've got wire wheel hubs, BTW.
BobHaskell
Here's a mock up of the test indicator set up I use
I made a nut that extends past the end of the wire wheel hub
Platinum
That's downright sexy, Bob! ;)(y)
My rig was crude. A piece of steel coat hanger wire threaded to fit the dial indicator stem.
J
joelodom
Thanks, everyone for your help so far. I've been doing a lot of homework and have most of the parts now.
I may need to clean up the axle stub threads. I see it's a 16 TPI UNF thread, Whitworth, 55 degrees, major diameter is 0.680“ and minor is 0.610“, but I'm still not exactly sure how to make sure I order the correct thread chaser. I'd hate to mess up the threads. Can anyone help me know how to make sure I select the correct thread chaser? Thank you again!
J
joelodom
After some research, I don't think what I posted a little while ago is correct. I think that front axle stub is 16 TPI 5/8" UNF, and I should clean it up with a thread file. I've never used a thread file before and I don't know if any 16 TPI file will work, but I'll figure it out. Advice appreciated!
Platinum
Snap-On thread repair file, you may find one >>> on Ebay by part number. <<< 11 tpi through 24, useful tool.
5/8"x16 tpi UNF sounds odd, though. Standard is 18 tpi.
Platinum
IMHO a thread file is a "choice of last resort." A thread chasing die would be better. As for pitch, anything you do to clean up or "repair" damaged threads is somewhat destructive.
J
joelodom
Hello again. I started the wheel bearing project a few days ago. The axle nut was threadbare and would no longer accept torque without slipping, and the axle itself was in bad shape and wouldn't accept a fresh nut (new new from a major vendor). I ran a thread chaser down it and am I'm in good shape now.
I did a bunch of research and measurements and have confirmed the following, which I'm very confident of (and even verified with another person in my MG club who has had the same issue). The axle is an unusual 11/16" - 16 thread. That matches what the nut vendor said, too.
If anyone ever needs help fixing their axle thread, reach out to me and I can share photos and advice. Posting this here for posterity.
Now on the setting the shims and finishing the job!
J
joelodom
Done! The bearings are re-greased (they didn't need replacement) and the worn parts are new. If anyone has any questions about this process, I have extensive notes and photos I would be happy to share.
YakkoWarner
I would be very interested in how this process is done, because my sum total of information on the subject is summed up as "don't do them like normal American style bearings or you'll eventually have broken spindles"....
J
joelodom
Sure. I just sent you a private message about getting access to my personal notes as a PDF.
Z 3000 Front Wheel Bearings Austin Healey 3
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
G MGB Front Wheel Bearings MG 2
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
W Front Wheel Bearings Austin Healey 3
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
prb51 Front wheel bearings Triumph 13
fmichaels front wheel bearings Spridgets 5
healeyneil front wheel bearings Spridgets 5
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
txtr3 TR2/3/3A TR3A front wheel bearings and seals Triumph 4
Simon TR4a Front wheel bearings Triumph 2
S Repacking Front Wheel Bearings Austin Healey 16
77MidgetMkIV Front Wheel Assembly Question [bearings] Spridgets 8
M Front Wheel Bearings Spridgets 7
N Front Wheel Bearings [...Removal Of ] Austin Healey 14
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
