Hey, sorry it took me a while to get back to you about this. I used the bearings recommended on the Timken website (automotive section, refer to tapered bearing conversion ... it's an option under spridget). They were supplied via EB Atmus corp out of massachusetts, although I am sure they could be purchased about anywhere. They're metric bearings, as I understand it, and reasonably commonly available. The note on the timken website indicated that the washer on the end of the spindle, just before the castellated nut, should be shaved from 1/8th inch to 1/16th. It also said that should the assembly still be too long, you can mill a bearing surface (I'm not sure which one, as I was only 1/16th too long) to reduce the width.
However, instead of milling the washer, because I didn't have a mill handy, we simply cut the slots in the castellated nut 1/16th deeper (it has plenty of meat). This worked very well. I have some slop in the lower fulcrum pin on the passenger side, so I hear some noise over bumps on hard left turns (I'll get to that soon enough). I also discarded the spacers, as they're no longer necessary. The hub is stepped to accept the outer races, and the inner races are held in by the step on the inner face of the spindle and the washer/nut combination on the outside. If the spacers were retained, they'd either be too long, or if they were shortened to fit, they would do nothing or interfere with proper tightening of the spindle nut. In either case, they're no longer necessary due to the design of the tapered roller bearings. The transition is easy, with the primary trouble being the fact that the spindles needed a little sanding to get the inner bearing's inner race on smoothly. You'll need new nuts, cotter pins, and seals (2 each), and I believe that's about it. The cost for these items in nominal, and I got 2 complete sets of bearings for the rear (4 spherical ball bearings) as well as 4X each of the two types needed for the front (two complete sets) plus shipping for around $160. I figured it can't hurt to have plenty of bearings on hand, especially when racing.
