txtr3
Member
I started repacking the front wheel bearings on my 59 TR3A this weekend. I've read lots of step-by-step instructions, but never done it myself. I did the first wheel, and it seemed to go ok.
One thing I noticed, though, was that the new felt seal I ordered had a metal backing. The felt seal that came off the hub did not have the metal back. Are they done both ways? If so, is there any difference in procedure?
The instructions I was following called for tapping the metal seal backing into the hub. This would appear to create a metal-to-metal contact zone between the seal backer on the inner part of the hub, and the shoulder of the stub axle. Is this correct? Do you just some grease here?
On the second wheel, the metal seal backer doesn't want to fit in the hub (the hub surface is not smooth here, looks like somebody hammered on it in the past). I can probably pound it in, but I'm worried about pushing metal shavings into my newly packed bearings.
Any helpful comments for a novice?
Thanks,
Jiri
Thanks,
Jiri
