CraigLandrum
In the process of installing our steering wheel, stator tube, and control head, we noticed that the front wheels had some serious (> 1 inch) toe out, causing me to be question if it was even possible to be sure the steering wheel was going on straight.
So I insisted we fix the toe out so the front wheels at least exhibited some kind of sane configuration. To make a long story short, we fiddled with adjusting the tie rod ends/nuts until both front wheels were parallel or with a bit of toe in.
The factory manual calls for 7.68 inch distance between centers on the tie rod ends and that's about whet we ended up with. It also calls for 1/8 inch toe in (if I recall correctly).
Is there any way for a home garage guy to get close to the proper alignment or is this something that only grizzled vets with commercial tools can accomplish? Any tips for doing this at home would be appreciated.
