front wheel bearings
healeyneil
I think I read a post a while back that mentioned a kit to fit taper roller bearings at the front. Any experience? Im tempted to go to my bearing stockist and get an equivalent from them and see how it goes
ChrisS
I used the following bearings and races: 07097/07204 (inner) and 05066/05185 (outer) with a 13649 seal. I have also used a 07098 inner bearing when the 07097 was unavailable. The only difference is the ID: 0.9842” / 25 mm for the 07097 and 0.9835” / 24.981 mm for the 07098. Both will use the large race for the series 07204.
The alternative bearings are the 30205 and 30303 which are wider. The 07097 / 07098 bearing is 0.5910” wide where as the 30205 is 0.6398”. 05066 is 0.5662” wide verses the 30303 at 0.6004”. This affects the adjustment to the distance piece if that is going to be reused / modified / shimmed. There is a good discussion about the distance piece reuse here https://www.team.net/html_arc/spridgets-mod/200203/msg00008.html The worry is that the race can spin without the distance piece and chew up your spindle.
If you reuse the distance piece you will most likely need to file the groove in the castle nut to get the cotter pin in; it should be pretty soft and easy to do. You want to go long on the distance piece / thick on the shims and work your way down to 0.001" and 0.003" end float at about 45 ft-lbs torque. Start with about .200” and work down (assuming the 07097 and 05066 bearings – I haven’t do it with the 30303 / 30205). Try not to torque the nut with insufficient shims-the rollers or races will flat spot. Also, when you get done the rotor will be slightly off center with the caliper and the caliper may need to be shimmed.
Another piece if information is a friend of mine replaced his 7 year old roller bearings with new ones and ran into a problem. Apparently the new inner bearing 07098 that he used had a lip on the retainer that interfered with the distance piece; He had to put a chamfer in the ID of the big end of the distance piece.
jlaird
Jeff your link above was very intresting. thanks
healeyneil
healeyneil
I knew it! People have the info you need! This sort of stuff makes the forum worthwhile.
thanks to everyone. Neil
regularman
I get bearings at my local applied technology, it used to be the old dixie bearing. They have local places in most towns and they will be much cheaper than going through a LBC car parts distributor. I think I payed less than $10 a piece for mine. Those numbers are universal across all bearing manufacturers, you can get those bearings a any advance auto parts if you can find someone who has any brains, ignore any letters after the numbers, the basic numbers will give you the same bearing.
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
Z 3000 Front Wheel Bearings Austin Healey 3
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
G MGB Front Wheel Bearings MG 2
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
W Front Wheel Bearings Austin Healey 3
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
prb51 Front wheel bearings Triumph 13
fmichaels front wheel bearings Spridgets 5
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
txtr3 TR2/3/3A TR3A front wheel bearings and seals Triumph 4
Simon TR4a Front wheel bearings Triumph 2
S Repacking Front Wheel Bearings Austin Healey 16
77MidgetMkIV Front Wheel Assembly Question [bearings] Spridgets 8
M Front Wheel Bearings Spridgets 7
N Front Wheel Bearings [...Removal Of ] Austin Healey 14
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
