front wheel bearings
fmichaels
new bearings are coming tomorrow. the old inner bearings came off with some persuasion. what is the process for installing new inner bearings? is it a pressure fit and are their special tools to do this? i am not a special tool guy and would prefer the handymans approach to the problem. i notice the old inner bearing has a plastic bearing retainer. any concerns there?
spritenut
Just be sure to drive the new bearing in straight.
Also the thrust sides face each other.
If the old bearings had a plastic retainer, they are the new not so good bearings.
jlaird
Should not need to drive them on, tight fit yes but clean up spindle really well, maybe even a pit of fine paper, then clean really good, should be very snug but not need to drive on. just tap.
fmichaels
fmichaels
thanks for the advice. any reason to freeze the spindle to assist installation?
jlaird
Oh no, just a real good clean up.
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
Z 3000 Front Wheel Bearings Austin Healey 3
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Front wheel bearings?? Spridgets 8
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C TR2/3/3A Front wheel bearings Triumph 8
T TR2/3/3A Front wheel bearings direction and torque Triumph 1
Jim_Gruber Removing front wheel bearings from hub Spridgets 6
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
G MGB Front Wheel Bearings MG 2
P Bugeye Front Wheel Bearings? Spridgets 1
Morris Front wheel bearings Spridgets 9
N Front Wheel Bearings?? Spridgets 4
Rut Front wheel bearings [again] Spridgets 12
R TR 3b front wheel bearings Triumph 5
D Front wheel bearings Austin Healey 48
P front wheel bearings for 79 midget? Spridgets 4
Jer re-packing front wheel bearings Spridgets 3
tomshobby front wheel bearings Spridgets 13
N TR6 How to check TR6 front wheel bearings Triumph 1
58Custom Any tricks to changing front wheel bearings? Spridgets 7
Atrus INeed opinions/experience - front wheel bearings Spridgets 7
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
W Front Wheel Bearings Austin Healey 3
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
T Front Wheel Bearings Triumph 26
T TR6 tr6 front wheel bearings Triumph 15
MGFever Upgraded Front Wheel bearings Spridgets 8
T "How To" front wheel bearings Triumph 18
prb51 Front wheel bearings Triumph 13
healeyneil front wheel bearings Spridgets 5
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
txtr3 TR2/3/3A TR3A front wheel bearings and seals Triumph 4
Simon TR4a Front wheel bearings Triumph 2
S Repacking Front Wheel Bearings Austin Healey 16
77MidgetMkIV Front Wheel Assembly Question [bearings] Spridgets 8
M Front Wheel Bearings Spridgets 7
N Front Wheel Bearings [...Removal Of ] Austin Healey 14
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
P 100/6 Front Wheel Alignment Austin Healey 10
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
B Front Wheel Camber Setting Austin Healey 8
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
A Front wheel bearing issues Austin Healey 11
Rob Glasgow Front Wheel Bearingsknow Austin Healey 4
TRclassic3 TR2/3/3A Front wheel bearing adjustment Triumph 5
