disk brake dust
HEALEYJAG
My 2007 s-type will coat the wheels with brake dust after 2 days......will wax or any other polish etc. help repell the dust and stop it from accumulating on the wheels.
Thank you:
Pete
Keoke
Hi Pete, no there are no repellents that do that. However they can help prevent detrimental adhesion. There exists a shield that can be added to the wheels to prevent the build up of the brake dust. Check your dealer or local auto part supplier.--Fwiw--Keoke
Monark192 Disk Brake Dust Covers Spridgets 8
T TR2/3/3A TR3A Disk Brake Question Triumph 10
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
R Bugeye disk brake conversion Spridgets 10
I Bugeye drum to disk brake conversion Spridgets 23
Csarneson Disk Brake Conversion - Pipe Flare Problem? Austin Healey 15
O 57 100-6 Disk Brake Upgrade kit Austin Healey 9
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
The_architect Looking for early disk brake steering arms, BTA 648 and BTA 649 Spridgets 25
Boggsy64 MGB Semi metallic disk brake - break in MG 10
B Rear Backing Plates for Disk Brake Conversion Spridgets 6
TimK Uneven wear on Healey front disk brake pads Austin Healey 2
T BN1 wire wheel sizes w/disk brake conversion Austin Healey 6
cdsmith disk brake setup question... Spridgets 3
CraigLandrum TR2/3/3A TR3 front disk brake squeal cause? Triumph 11
rlandrum TR2/3/3A TR3A Disk Brake Rebuilding Triumph 9
7 Getting disk brake calipers back together Triumph 1
PATR8 Willwood disk brake conversion Triumph 5
D TR2/3/3A TR3 Brake Disk Triumph 3
Johnny AH Disk Brake Calipers Austin Healey 6
John Loftus Disk Brake assembly questions Austin Healey 34
ChrisS Disk brake conversion Spridgets 10
S Rear Disk Brake Conversion Austin Healey 8
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
RAC68 Disk Replacement for Rear Drums Austin Healey 1
Jim_Gruber A Quality Piece of Kit for Bugsy IV - Creative Spridget Rear Disk Brackets Spridgets 8
Rob Glasgow Replace clutch disk? Austin Healey 8
Z Swept area of disk vs drum Austin Healey 2
B Front Disk Conversion Spridgets 3
H disk brakes on 100-6 question Austin Healey 14
PAUL161 Throttle Disk Changeover MG 2
C Disk Brakes for 58 Anglia Other British Cars 2
richberman AH Spares Disk conversion question Austin Healey 4
rjc157 clutch disk Austin Healey 7
richberman pictures of front disk conversion? Austin Healey 31
PAUL161 Solid Throttle Disk for HIFs MG 7
M rear disk brakes Spridgets 0
T TR 2 - 4 Clutch Disk Triumph 4
J inboard disk brakes Triumph 2
F Difference between disk and wire rotors???? Spridgets 1
T When to replace the throttle disk? Triumph 4
T Conversion: Wire wheels to disk wheels Spridgets 3
Brian_James Correct color for Bugeye disk wheels?? Spridgets 7
heliguy Clutch Disk Confusion? Triumph 2
rlandrum TR2/3/3A TR3A Disk Brakes Triumph 4
Monark192 Disk conversion completed Spridgets 6
W Where is the oil on my clutch disk coming from? Austin Healey 14
T TR2/3/3A TR3 tire size & recommendations for disk wheels Triumph 18
B T-Series Plastic disk switch encased in seat bottom foam?? MG 11
zimmy front disk brakes Spridgets 9
