Throttle Disk Changeover
PAUL161
I've asked this before, quite a while ago, but the old brain didn't retain the answer. Will a solid disk from a HS-4 fit and replace the ones in the HIF-4 carbs? Is the bore in both carbs the same? PJ
Yes, some of the HIF4s have a flush enrichment tube at the throttle disc, and those carbs will take the early HS4 solid butterfly without any mods, then some of the HIF4s have protruding tubes there, those tubes can be carefully ported flush with the carb body and the solid butterfly used, those carbs with the protruding tube had slot in the bottom of the original poppet valve butterfly, and some have notched the solid butterfly to do the same thing, but I would rather opt to flush the tube, you'll get a much better idling car that way.
Hope ths helps
PAUL161
PAUL161
Thanks very much Hap. I believe it was you who gave me that information some time ago. I've gotten to the point where I have to write every thing down, because if a month goes by, it's lost in the old brain.
The wife and I moved to the North Eastern section of Oklahoma since the last time I saw you at the track some time ago, moved close to our son. Bought an old horse farm. Have a nice big shop to work on the cars. PJ
PAUL161 Solid Throttle Disk for HIFs MG 7
T When to replace the throttle disk? Triumph 4
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 30
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
catfood Throttle return mechanism on the BN1 Austin Healey 4
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
M Throttle pedal problem Austin Healey 8
bighealeysource Strange problem with throttle staying open Austin Healey 6
A Throttle Pedal Height Austin Healey 17
Bob_Spidell Throttle Bushes Austin Healey 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rob Glasgow Overdrive Throttle Switch Austin Healey 9
Rut TR4/4A SU throttle linkage and brackets Triumph 5
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
P Bj8 rhd cable throttle conversion - help Austin Healey 6
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
TomMull Spitfire Throttle linksge needed Triumph 10
TomMull Post-War Other Herald carpets and throttle issues Triumph 4
MY66AH Throttle Linkage Spridgets 9
doc50 TR2/3/3A Throttle sticks Triumph 8
J TR2/3/3A Need a part for the throttle shaft. Triumph 4
