Rob Glasgow
Since I have the engine and transmission out of the car during the restoration, I thought I might replace the clutch disk even though it has only 18,000 miles on it since it was replaced. When I removed it, it looked fine with no damage. I compared the thickness of the old disk to a new one I purchased to install. They both measured .34 inches across the friction material so it doesn't look like the old dish has worn. The old dish is a Borg and Beck, the new one has no name but I purchased it from Moss.
What are your thoughts? Should I go ahead and install a new disk at this point or just reinstall the old one? I know Borg and Beck is a well know company, but I'm not sure of the quality of the new disk, although it looks OK. The old one has a thicker collar where the transmission shaft goes. I can always return the new disk if I don't use it.
