TR6 TR 6 Head Studs, replace?
gbtr6
I am getting my engine machine work done and the shop wants to know if they should replace the head studs. I am not aware of any issues with mine, no bad headgasket situation. I do run a bit higher compression, but have in the past with no trouble. I know it's possible for them to stretch. Any ideas? I am leaning toward re-use.
Thanks,
Perry
TR3driver
Great Pumpkin - R.I.P
A trick I got from one of the racers is to spin a new nut down the clean threads. If the nut binds about 2/3 down, discard the stud. The most likely (and most harmful) place for them to stretch is just under where the old nut sat.
I've found a few TR3 studs that flunked that test; but never had a failure with original studs that pass the test. (Of course I also don't re-use them if there is any obvious corrosion or damage.)
glemon
What he said, never replaced a stud on several head and engine rebuilds, never had a problem, Randall's test makes sense, if money is no object, and/or you are building a racing engine or high performance street motor you may want to look into ARP studs or the like. PS, if you are keeping the old studs and a couple don't pass the thread test drop me a line, I have a couple extra TR6 blocks and I am sure at least a few of the studs are good.
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
B 1500 head studs Spridgets 3
D BT7 head manifold studs Austin Healey 7
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
alanjohnturner General TR Head-studs, torques and sizes Triumph 2
Boink Hardened/strong head studs on a 1275 - torque? Spridgets 5
T Frozen head studs Austin Healey 11
tinman58 TR2/3/3A Removing head studs TR3 Triumph 15
A Replacing 3.8L cylinder head studs Jaguar 7
R ARP head and connection rod studs? Spridgets 15
Darwin Spitfire Spitfire head studs? Triumph 6
M ARP head studs Triumph 5
Basil Head studs Racing 1
C Wedge TR8 Head Studs Triumph 6
B TR6 TR6 Head Studs Triumph 4
martx-5 ARP Head Studs Triumph 21
Michael Oritt MGA Larger head studs in MGA engine MG 6
Michael Oritt Larger head studs in MG engine Racing 14
healeynut Head Studs Jaguar 9
tomshobby head studs, Paul Triumph 5
Morris ARP Head studs torque... Spridgets 2
R TR6 TR6 head studs Triumph 1
jlaird Question-Head studs Spridgets 2
G It was free so who cares...getting head studs out Triumph 10
GB1 Head Studs Spridgets 8
ChrisS ARP Head Studs Racing 2
jcatnite Head Studs Spridgets 15
M Moss Brand Head Studs for 1500 Spridgets 4
V TR6 TR6 Head Studs Triumph 17
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
