ARP head studs
mallard
Who has the best price on the Head studs for TR3? I found $184.00 is that a good price?
DNK
I Got a free set for give away for a 14 bolt 3500 motor
TR4nut
You can beat the $184 price I think. Here's one ebay seller, I think I've seen them cheaper than this too: arp head studs
Edit: Now this price is getting better: NoLimitMotorSport
And finally, to break the $100 barrier: 98$ deal
M
mallard
I don't know why I didn't see those, Thanks
billspit
The only problem with nolimitmotorsport is that they may not have your set in stock and it can take months to get them. I got my rod bolts in a few weeks. They wanted 2-3 months for the head studs. No idea why so long.
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
DrEntropy MGB And now, NO ARP head studs to be found! MG 13
T TR4/4A Are the ARP head studs worth it? [ducks for cover] Triumph 19
R ARP head and connection rod studs? Spridgets 15
martx-5 ARP Head Studs Triumph 21
Morris ARP Head studs torque... Spridgets 2
ChrisS ARP Head Studs Racing 2
RJS TR4/4A ARP Head Stud Question Triumph 2
hondo402000 TR6 TR6 ARP head bolts Triumph 4
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D ARP big end bolts. Spridgets 7
G TR4/4A ARP Bolt Torque Specs Triumph 10
T TR4/4A Should I use ARP Assembly Lubricant for Engine Assembly and Fastener Installation? Triumph 2
T TR2/3/3A ARP connecting rod bolts Triumph 2
RedTR3 TR2/3/3A Moss [ARP] Flywheel Bolts Triumph 16
F Using 12 point ARP style rod and main bolts Spridgets 9
hondo402000 TR6 TR6, 71 model flywheel bolts, ARP Triumph 2
S I just bought ARP main stud kit 206-5405 Austin Healey 4
L ARP fastners. Spridgets 4
Basil ARP studs too short Triumph 18
DNK ARP Studs Triumph 74
Glen_B Torque for ARP mains Spridgets 1
G ARP Assembly Lubricant....how to use the stuff Triumph 9
Morris ARP studs torque and blown headgasket Spridgets 17
7 ARP bolt kits Triumph 2
A ARP flywheel bolts--install Latest [no Loctite] Triumph 11
healeyboz ARP bolts Spridgets 6
healeyboz ARP bolts Spridgets 5
ChrisS ARP Rod Bolts Spridgets 7
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
