martx-5
I'm finishing up the TR3 engine, and have installed new ARP head studs. The OE torque recomendation is 100-105 lb/ft. ARP suggests to use 90 lb/ft when using their assembly lubricant based on 75% of the fasteners yeild strength for this size stud. OK, no problem, the stud kit comes with their lubricant. However they say that if you are using 30 wt motor oil as a thread lubricant, torque to 130 ft/lbs.
Astonishing that a different thread lubricant has that much affect on how tight the nut is! I went on their site to see why there is so much of a difference, but the blurb was just about friction. Does friction suck up that much torque when tightening a nut??
