T-Series Clutch Slave-rebuild or replace? [Pretty nasty...]
RickB
Right now I have 3 LBC's none of which are drivable.
I was going out to work on the B this morning when I glanced under the Midget and saw a wet patch on the road.
Popped the hood & found water leaking from the bottom of the water pump. We took it out on an MG club run yesterday - I noticed there wasn't any heat coming out from the heater but thought it was just cold out so no biggie & the water temp never rose above 180F.
Called NAPA and ordered a new pump, will be here tomorrow they say.
The B had leaked several quarts of oil the last time my wife took it out so its been grounded since, waiting for me to take a look at it.
The leak as it turns out was due to the small hose going to the oil pressure sensor. I removed it and took it in to NAPA but they couldn't come up with a replacement and said I should bring in the fixture it hooks up to or the piece off the block where it connects.
I go back home and take the piece off the side of the block and decided to go across the street to True Value and see if they had anything. They did have a plug, so I got that and some tape to seal the threads. The thought was I could plug the hole until I could find the right thing for the job.
So I plugged it up and then got in to drive it out to NAPA...
NO CLUTCH!!!
:nopity: :wall: :eeek: :pukeface:
I have been having to add a little fluid to the clutch master for the past few months, but today it was low again and the pedal goes right to the floor.
Where is all the fluid going?? It's not around the master or dripping through to the drivers side floor, so where is it.
I jacked up the car and looked at the slave. The rubber seal on the end looks a bit bulgy and everything is drenched with oil, so much so that I can't tell if any brake fluid has been escaping.
I'd bet on it being a slave cylinder problem at this point, but it's pretty hard to tell.
All in all not such a great LBC day here.
Jagboy69
Re: Pretty nasty LBC day at my house
Rick, I've been exactly where you are too many times. Too many LBC's and not a one of them worth a darn. I finally figured out what I wanted and sold everyone of them. I then used the money and bought an E-type. Trust me, it's like owning a very expensive midget. Same problems, same BS, same parts will be in on monday.
I drive a trusty Nissan as a daily driver and when the Jag breaks down, the garage door gets closed and I'll see you when I see you. It's always a love and hate relationship with these cars. I drove a BGT for years and piled major miles on it. I could adjust the valves in complete darkness, change the fuel pump while fighting off fire ants on the side of the road and learned how to clean antifreeze off the INSIDE of my windshield while doing 70mph on Interstate 40. It was then I decided ONE english car at a time was enough. Sure the cars are cheap to buy and I could fill up my backyard with them if I wanted to. But keeping them in tip top shape is a different animal. Hang in there. Sooner or later you'll end up like me or in the nut house!
RickB
RickB
Thanks Jason, I guess I haven't gotten that far yet. :wink:
So what is the general consensus on whether to rebuild the clutch slave or replace it?
RickB
RickB
I just called NAPA and they say there are two possibilities for the slave rebuild kit - 1 inch bore & 1.25 inch bore.
How do I know without removing the thing and measuring?
Does the 70 MGB GT have 1" or 1.25" clutch slave?
Jagboy69
Rick I can't remember which size mine was. It was a difference between the B and C I think. It's a quick and relatively painless ordeal to remove the slave. Then you can measure it. I was always able to kit my slaves. I did however NOT rebuild the brake master on my BGT. Same goes with the wheel cylinders on the back brakes. New ones were so cheap so why bother. Try these guys for parts. I have been finding them cheaper for my Jag parts that my usual suspects.
https://www.bpnorthwest.com/.sc/ms/dd/MGB...der%20MGA%20MGB
compared to vicki B https://www.victoriabritish.com/icatalog/mg/full.aspx?Page=127
RickB
RickB
Thanks Jason, that is a lot better at BPNW.
I've been on their site before, but never ordered from them.
EDIT:
I looked up the rebuild kit, $12 shipping for a $6 part. I guess it would be better if I was ordering something bigger & more expensive.
RickB
RickB
I bought the kit from Pat's MG & Triumph parts on Ebay.
I have bought several parts from him, he said he would try to get it out to me yesterday. I asked him if I could add a few bucks for priority shipping and he did it for just $1 extra. Nice guy!
Scott_Hower
Replace it. Unless it's an original AP Lockheed in good shape (decent bore). Your labor is free; the parts price difference is not that great. Do it once.
RickB
RickB
Well seeing how I was down two cars I opted to bleed the clutch and see how it went. The stuff that came out bore little resemblance to brake fluid.
Afterwards it worked better than ever. I know I still have to rebuild or replace, but I have a driver for the time being anyway!
RickB
RickB
It was sunny and warm today, so I rebuilt that slave cylinder.
The bore & the piston were dirty but not pitted.
I cleaned it all up and put it back together with the rebuild kit then SWMBO and I bled the thing and WahLah - works better now than it ever has as long as I've owned it!
Shifting into 1st & reverse is remarkably easier too! :wink:
Jagboy69
Hey Rick, Glad to hear your back on 4 wheels again. Sometimes it was difficult on my BGT to slip into reverse so I was taught to shift back into first, lightly lift on the clutch once and then shift into reverse. Some old man told me it slows the synchros down and allows easier engagement. Anyone know if this is why this actually works? I know it does, but have never really been sure this is the WHY part of it.
While I'm at it, a beer to the first person that knows why cars whine in reverse and not in FWD gears???? (Let's see who gets this one right!) :smile:
RickB
RickB
I have to try 1'st or 2nd before going into reverse, it does make it slip into reverse easier. It really does seem to "slow" something in the gearbox down - even when it isn't quite ready to slip in you can hear / feel the slowing of the gears when doing this.
Why it whines in reverse?
A guess: None of the gear faces that are coming into contact under load have been worn in like the opposite side in the forward gears so they make a bit of noise, all of them building up to an audible level and the faster you go in reverse the higher the pitch.
Jagboy69
That's a good guess and sounds logical, but no. Anyone else want to take a stab at it. It has to do with $$$.
billspohn
Scott_Hower said:
Reverse is a straight cut gear. Costs more to make a helical cut.
On early cars, so is first and they whine as well.
OTOH, a straight cut gear is supposedly slightly stronger than a helical gear. I have one of the fairly rare factory competition gearsets (developed for the racing MGCs) that are straight cut in ALL gears. They make a nice whine as RPM increases.
In contrast, my old Lambo not only has helical cut gears on all 5 forward AND reverse, it also has synchro on reverse! Other end of the spectrum.
WA1KWA
The Getrag 265 fitted to 5, 6 & 7 series BMWs a couple of decades ago had a synchro reverse gear.
Colin
Jagboy69
Nice job Scott. Looks like I owe you a beer sir!
Jason
Z Clutch Slave Cylinder Rebuild Austin Healey 3
Z Clutch Slave Cylinder Rebuild Spridgets 2
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
K TR2/3/3A Clutch slave "return spring"? Triumph 3
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
BobHaskell For Sale Clutch Slave Cylinder Bleeder Extension Austin Healey Classifieds 13
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
R clutch slave cylinder Triumph 11
W Clutch slave cyl. Austin Healey 4
S XJ6 Mk1 clutch slave question Jaguar 0
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
K TR4/4A Adapter that connects Clutch MC to the pipe that goes to the slave cyl? Triumph 4
R Bug-eye clutch slave cylinder and brake cylinder kit interchange Spridgets 1
B MG midget Clutch slave cylinder Spridgets 5
WillR MGB new clutch slave cylinder MG 3
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
A clutch Slave boiling Spridgets 6
Joe Reed MGB Clutch Slave push rod...past its prime MG 2
GTP1960 TR2/3/3A Clutch slave cylinder / push rod alignment Triumph 10
trotti Access to the clutch slave cylinder bleed screw Austin Healey 41
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
RickB MGB Trouble bleeding new clutch MC & slave MG 6
TomChar TR6 '74 Clutch Slave Cylinder location Triumph 8
K TR2/3/3A Resolving my Clutch slave issue.... Triumph 3
CJD TR2/3/3A Clutch slave stay rod Triumph 11
RedTR3 TR2/3/3A Clutch Slave Adjustment Triumph 5
K TR2/3/3A Further to Clutch Slave Adjustment...... Triumph 2
K TR2/3/3A TR6 gearbox on TR3: re clutch slave adjustment. Triumph 13
RJS TR4/4A Clutch Slave Size? Triumph 5
G MGB STILL working on clutch slave MG 37
G MGB Clutch Slave Cylinder MG 34
RJS TR4/4A Clutch Slave mount into cross shaft Triumph 3
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
C 1961 3000 Recommendations for Clutch Slave Cylinder Austin Healey 5
S TR6 Clutch slave piston shooting out during bleeding Triumph 8
K TR2/3/3A TR3A Clutch Slave Bleed Issue? Triumph 8
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
J T-Series clutch Master cylinder or slave? MG 8
Boink Clutch Slave Cylinder dribble... Spridgets 20
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
D Clutch slave travel Triumph 12
K TR2/3/3A TR3 Clutch master and slave bleed issues? Triumph 5
L 1275 Clutch Slave Cylinder to BE Clutch Line Spridgets 14
tahoe healey Clutch slave upside down Austin Healey 5
