TR4/4A CV Axles TR4A
KVH
Merry Christmas to all, and all the Best for the New Year!
I'll soon be installing my new CV Axles from Goodparts.
I've had a load of good advice about the process from the folks right here.
Before I start, next week, if anyone who recently has installed them has any further words of advice, I'm all ears.
Thanks.
glemon
No knowledge whatsoever, but share what you learn in the install and driving with the new things with us, I am sure there are more curious monkeys out thare than me on this subject
nissanite
I installed them in my Rat-co frame. The installation is quite easy. I would suggest checking & or replacing the 6 flange studs while everything is apart. Goodparts is a great source. I have not driven my car yet but it rolls great (haha)
KVH
KVH
Are you referring to the studs in the trailing arm, or just the studs that hold the CVs to the differential?
Richard suggested I not worry about the trailing arm studs if they are all intact and aren't stripped. I'm ready to replace, re-drill and use KeenSerts when and if the time comes.
Why aren't you driving and testing out those new axles?
nissanite
Yes, I was talking about the trailing arm studs. I agree with Richard about the studs. I removed mine & inspected, replaced with red loctite & torqued properly with no problem. Just saying, my car was always in FLA with no corrosion.
My car is a longterm resotration that still has the body off. Maybe some day.....
BobbyD
If you're going to the trouble and expense of installing the GP CVJs why not take the time and small added expense to<span style="text-decoration: underline"> redo all of the TA studs with Rick Patton's TA Repair kit?</span> These studs are known to strip and are a fairly common fail point. I can't tell you how many of the guys in 6-Pack have done this repair and raved about how easy the kit made it. Like Paul Rego <span style="text-decoration: underline">I've done both the TA Repair and the GP CVJs on my 6.</span> I highly recommend doing both.
glemon
I noticed the the rolling dyno HP numbers for TR6s are well below published BHP figures common from British and other cars from the period, but maybe even a little moreso for the 6s, does anyone know do the U joints contribute to driveline friction loses to RWHP, and 2nd would the CV joints be better? (ie less HP loss)
poolboy
RG does say "more horsepower to the road" in his advertisement.
KVH TR4/4A TR4A IRS Differential and Axles Removed Triumph 11
tban52 TR4/4A TR4A axles Triumph 9
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Jayplum TR2/3/3A Wheels, tires, hubs and axles Triumph 22
K For Sale TR3 Axles in good condition Triumph Classifieds 0
Sarastro TR4/4A Are these axles and hubs usable? Triumph 12
T WW Axles in stock Bugeye housing? Spridgets 7
K TR4/4A Rear axles on live axle car Triumph 8
M TR6 New Moss [UK] front stub axles and bearings kit TR Triumph 4
Rut Axles Spridgets 1
hondo402000 TR6 TR6 Heavy duty front Stub axles Triumph 12
R IRS Rear Axles Triumph 16
BoyRacer BJ8 front stub axles & hubs for bolt on wheels Austin Healey 0
M MGA MGA Disc Brake Axles? MG 2
M MK1 or XK150 Spindle Axles? Jaguar 0
T BugEye - identifying rear axles[?] Spridgets 0
Brosky Trailing arm stud repair and new CV axles done Triumph 14
M Wire wheel axles Spridgets 4
T MGA MGA vs MGB rear axles and differentials MG 31
bthompson More leaky axles... Spridgets 6
Michael Oritt Winner's Circle axles Racing 2
I Amazing axles - thanks Doug! Spridgets 0
B Tire Selection / LSD and Axles. Racing 10
G TR6 TR6 CV axles Triumph 12
drooartz Progress: axles and hubs out Spridgets 14
glemon Strengthened Stub Axles All That? Triumph 5
Branson question bout axles Spridgets 8
R Lotus M Elan axles Lotus 1
A break in oil pressure--5speed conv--cv joint axles Triumph 11
T TR6 tr6 axles Triumph 3
Michael Oritt Sprite axles Racing 4
Michael Oritt MGA rear axles Racing 2
msoylemez Question on Hardened Axles Spridgets 34
YankeeTR TR2/3/3A I need some info on broken TR2 Lockheed axles..... Triumph 0
LastDeadLast CV Axles/hubs from Goodparts Triumph 31
R TR6 Spline play on TR6 axles Triumph 2
drooartz Wheels w/o rear axles, or a Midget dolly Spridgets 1
Westfield_XI Uprated axles for wire wheel hubs/Frontline Spridg Spridgets 6
DNK Those nifty Axles Triumph 7
tony barnhill MGB MGB Axles & Hybrid Rear End MG 129
tony barnhill MGB MGB Salisbury Axles MG 7
G Has anyone uprated the rear axles to CV joints? Triumph 47
Geo Hahn Bugeye Rear Axles Spridgets 6
SilentUnicorn rear axles Spridgets 19
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
