break in oil pressure--5speed conv--cv joint axles
ALLAN
OK, got my car on the road after initial run in a week ago, ran it up and down the rpm range and sometimes under load for a good break in. Here is my oil pressure, cold- 50 at idle, 75 above 2500rpm. hot- slightly less than 25 at idle and 65 above 2500rpm. Does a little less than 25 seem low for hot idle?. Engine temp is good, I am running the aux. oil line to the valve train.----------Some of you might remember I installed the Supra 5sp conversion from Australia--everything worked and shifted flawless. Also I installed the Ocala CV joint axle conversion, thats the one that Alana installed, they worked flawless. ---Even though the trans conversion is working great I wouldnt recomend that company from Australia because there is a big lack of customer support, hard to get through on the phone (and expensive) and emails go unanswered, because of this-- things are left to your own thought and engineering on some of the installation, the instruction are very generic and not detailed, it would probably be alot better to stay with one of the American conversions.
R
RonMacPherson
Do you have a contact for the Ocala Axles? Tried google, but got nothing.
AltaKnight
Your oil pressures sound fine, don't worry, just drive!
A
ALLAN
Re: break in oil pressure--5speed conv--cv joint a
https://www.cvaxles.com by phone you have to ask for kevin he is the owner and is the one to place an order with. The last time I looked Goodparts was selling them--made by Ocala. I paid $1500 including shipping almost a year ago but Goodparts charges more---Kevin might tell you to go through Goodparts but I dont know for sure.
R
RonMacPherson
Mahalo Nui Loa!
A
ALLAN
Yes I did install cam bearings. The oil pressure goes up immediately on throttle but that hot idle oil pressure makes me a little nervous. I had installed my own aux. oil line before the rebuild --it was a small plastic line with a hole about 1/2 the size of the new stainless line, maybe thats it. I guess if the oil pressure stays good as it is above 2500 (its at 50 at 2000) there shouldnt be any problems??
vettedog72
It would be an interesting test to plug off the line to the rocker and see if there is any change to the oil pressure at idle.
A
ALLAN
I just installed my old smaller line, will start it up in the next couple days and see what happens, I had good idle pressure with the old aux. line. in the old engine.
aerospike
Your oil pressure sounds about like what I'm seeing. I've been concerned about 25psi at hot idle too. I put on a spin-on filter adapter about six months ago. After that, I had much lower pressure and had to adjust the pressure relief screw to get where I am now. I can't remember ever being worried about my oil pressure before the conversion so I've been thinking about going back to the original configuration to see if my pressure improves. Anybody else seen this with a filter adapter?
A
ALLAN
Its not the spin on, I had the spin on installed on the old engine with 40lb at hot idle.
mjobrien Initial Oil Pressure - Oil for break in? Austin Healey 20
doughairfield Oil during engine break in Triumph 6
K Memory Refresh:What oil to use after break-in? Triumph 1
2wrench Need recollection refreshed on break-in oil. Triumph 8
N How much oil should an engine use on break in Triumph 20
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
N Break In Oil for a rebuilt engine Triumph 23
Bruce_B Break-in of Engines and ROTELLA oil Spridgets 17
K Break in Oil...What's the general consensus? Triumph 7
Z TR6 Best break in oil for rebuilt TR6 motor? Triumph 35
jhorton3 Break-In Oil Spridgets 5
M Break-in Oil Triumph 6
Carlbanan56 MGB MGB rear break rebuild MG 6
D Back on the Midget after a vacation and work break. Spridgets 48
M Wedge TR7 break fluid Triumph 7
D Made a sheet metal break. Restoration & Tools 5
Gliderman8 Lights don't break FORUM Navigation Questions 23
D After a long break.... Spridgets 6
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
steveg Break In procedure Austin Healey 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
Rut Engine break in Spridgets 4
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
jlaird What is Bugeye master break painted with. Spridgets 4
SwamperCa General MG Lifter break-in MG 14
Boggsy64 MGB Semi metallic disk brake - break in MG 10
Scotsman TR2/3/3A Flushing break lines on TR3 Triumph 3
D break in engine Austin Healey 6
Scotsman Shimming Break Callipers Triumph 3
Scotsman break line compatibility with old connections Triumph 1
Scotsman "Coffee grounds" in break fluid Triumph 8
L Engine break-in period Spridgets 6
Sopwith_Camel long break Jaguar 7
J Dunlop L Racing Tire "Break In"? Racing 9
RJS Water Pump Break-In Triumph 10
tinman58 TR2/3/3A How to break in a TR3 motor Triumph 7
M Checking rear break drums and pads Triumph 7
M Break problem Other British Cars 8
bigjones Another embarrassing break down Spridgets 24
tahoe healey Hand break - broke Austin Healey 8
chicken Tips for getting the paint break line right Austin Healey 18
VelodromeRacer Engine break in? Racing 1
JPSmit Spring Break Accessory Spridgets 0
2wrench Miles to drive for break-in Triumph 4
Stewart So whats going to break next? MG 10
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
2wrench Gave you guys a break. Back with a few questions Triumph 13
T Break-in consideration for the new 4.0 heads? Triumph 3
