Break in Oil...What's the general consensus?
karls59tr
Bronze
I've put Rotella 15W/40 in the motor. I ran this rebuilt motor for a few hundred miles on Castrol 20W/50 but because of all that has been written about changes in the current oils and cam problems I've decided to go with the Rotella. I'm wondering if it would be beneficial to add a liter of STP? What ever happened to "Molyslip E"? I havent seen any lately at the Auto stores. Karl
YankeeTR
I think you are on the right track with the diesel oil.
STP does contain high levels of zinc and phosphurus but it's also (primarliy) a visosity index improver...it makes the oil thicker...I don't think that will be needed with a 15W40 oil.
I would suggest using GM's "Engine Oil Supplement"...use up to one can per oil change. With the diesel oil you may not need a full can each time but it certainly won't hust anything.
tomshobby
I agree with YankeeTR.
I just received a shipment of GM OES and am going to use it for my break-in per instructions. After I also plan on using it for an oil supplement.
I figure if GM recommends it as "outstanding protection against run-in wear and piston scuffing as well as run-in camshaft lobe and lifter scuffing resulting from insufficient lubrication" that it should work for me.
dklawson
I wasn't aware of the oil formulation changes until about a month ago. I did some googling about it and found the GM product highly recommended. I also contacted STP and asked whether their products still contained ZDDP (the zinc additive). They replied that it did and went on to recommend the following. For smaller engines (4 cylinders specifically) they recommend their product in the "red" bottle. If that's unavailable, they recommended adding to a warm engine 1/2 of their thicker product in the "blue" bottle.
YankeeTR
jackag91 said:
just out of curiosity, has anyone tried the lucas oil additives?
Many OTR truckers swear by Lucas products. I have used their engine oil additive in my big trucks for several years. I think it adds some extra protection from wear as well as adding certain additives that help when you run an extended oil drain period like I did.
My oil samples always came back looking better after 50,000 miles of use with Lucas than they did after 10,000 miles without Lucas. And my oil's additive package was always better with Mobil Delvac or Pennzoil than with Rotella oil. But I doubt that using Rotella will hurt your engine especially with normal drain periods. I just liked the extra protection that Mobil or Pennzoil gave with long drain intervals.
YankeeTR
I forgot about their two different formlations at STP.
The 'red' stuff will not thicken the oil like the stuff in the 'blue' bottle. That's important to know with new engines that are built to very close tolerances.
doughairfield Oil during engine break in Triumph 6
K Memory Refresh:What oil to use after break-in? Triumph 1
2wrench Need recollection refreshed on break-in oil. Triumph 8
N How much oil should an engine use on break in Triumph 20
Brosky Break in oil, normal driving oil......thoughts?? Triumph 43
mjobrien Initial Oil Pressure - Oil for break in? Austin Healey 20
N Break In Oil for a rebuilt engine Triumph 23
A break in oil pressure--5speed conv--cv joint axles Triumph 11
Bruce_B Break-in of Engines and ROTELLA oil Spridgets 17
Z TR6 Best break in oil for rebuilt TR6 motor? Triumph 35
jhorton3 Break-In Oil Spridgets 5
M Break-in Oil Triumph 6
Carlbanan56 MGB MGB rear break rebuild MG 6
D Back on the Midget after a vacation and work break. Spridgets 48
M Wedge TR7 break fluid Triumph 7
D Made a sheet metal break. Restoration & Tools 5
Gliderman8 Lights don't break FORUM Navigation Questions 23
D After a long break.... Spridgets 6
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
steveg Break In procedure Austin Healey 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Scotsman TR2/3/3A Drum break turning specifications Triumph 2
Rut Engine break in Spridgets 4
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
jlaird What is Bugeye master break painted with. Spridgets 4
SwamperCa General MG Lifter break-in MG 14
Boggsy64 MGB Semi metallic disk brake - break in MG 10
Scotsman TR2/3/3A Flushing break lines on TR3 Triumph 3
D break in engine Austin Healey 6
Scotsman Shimming Break Callipers Triumph 3
Scotsman break line compatibility with old connections Triumph 1
Scotsman "Coffee grounds" in break fluid Triumph 8
L Engine break-in period Spridgets 6
Sopwith_Camel long break Jaguar 7
J Dunlop L Racing Tire "Break In"? Racing 9
RJS Water Pump Break-In Triumph 10
tinman58 TR2/3/3A How to break in a TR3 motor Triumph 7
M Checking rear break drums and pads Triumph 7
M Break problem Other British Cars 8
bigjones Another embarrassing break down Spridgets 24
tahoe healey Hand break - broke Austin Healey 8
chicken Tips for getting the paint break line right Austin Healey 18
VelodromeRacer Engine break in? Racing 1
JPSmit Spring Break Accessory Spridgets 0
2wrench Miles to drive for break-in Triumph 4
Stewart So whats going to break next? MG 10
Geo Hahn TR4/4A Bad Break - Ouch! TR4 Fan Triumph 11
2wrench Gave you guys a break. Back with a few questions Triumph 13
T Break-in consideration for the new 4.0 heads? Triumph 3
